Thread: ?1.9 rocker question?
Results 1 to 8 of 8
  1. #1 ?1.9 rocker question?
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    who's rockers are the best to order from? zzp, 3800 perf, intense, anyone else? and should i run different springs or stick with originals? also new pushrods or originals? also motor has 60k miles on it if that makes a difference
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  2. #2 Re: ?1.9 rocker question?
    Get a new PCM before doing rockers.
  3. #3 Re: ?1.9 rocker question?
    Spearfish, sd
    why's that?
  4. #4 Re: ?1.9 rocker question?
    all rockers are the same. the real question you should be asking is which ratio and modded or rollers.
    from that question id tell you to do more searching.
  5. #5 Re: ?1.9 rocker question?
    Agree with Bio on the all doing the same job. You choose roller vs modded. Some rockers require different length pushrods that typically come with them.
    I'm more inclined to suggest a stock length pushrod rocker.
    And yes..please change the springs.
  6. #6 Re: ?1.9 rocker question?
    Spearfish, sd
    was planning on just doin 1.9 modded.. cheaper ones and i don't feel i would need rockers for the mild mods i got on there
    you say do more searching.. searchin what? from all i've read 1.9 rockers are simple and easy.. i'm not lookin for extreme performance
    and why change the springs?... all the sites say the stock springs are good to 6000 rpm
    again.. appreciate all feedback, just lookin for more detail to get some edumacation on this
  7. #7 Re: ?1.9 rocker question?
    i would agree that unless you rev over 6k RPM that youre fine on stock springs, but the likelihood of you breaking them increases the higher miles are on them. springs are just cheap insurance.
    i ran stock springs on my modded 1.9s and never floated any valves or broke anything.
  8. #8 Re: ?1.9 rocker question?
    Charles City, IA
    I might have some modded 1.9's for sale soon.
    SMGPFC Two Nipple General
  1. rocker question
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 05:57 PM
  2. Rocker bolts
    By Kerker48 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2009, 02:29 PM
  3. Rocker/Springs question.
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2009, 01:21 PM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. next mod question rocker or intake insert
    By mikeballer124 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 08:49 PM
