Thread: Bad mpg
Results 1 to 20 of 25
toby Bad mpg 10-27-2009, 12:05 PM
a98gtp4u Re: Bad mpg 10-27-2009, 01:31 PM
BillBoost37 Re: Bad mpg 10-27-2009, 01:43 PM
toby Re: Bad mpg 10-27-2009, 04:59 PM
rocafella2032 Re: Bad mpg 10-27-2009, 05:45 PM
toby Re: Bad mpg 10-27-2009, 06:25 PM
toby Re: Bad mpg 10-29-2009, 08:43 PM
toby Re: Bad mpg 10-31-2009, 06:21 PM
matt5112 Re: Bad mpg 10-31-2009, 07:27 PM
toby Re: Bad mpg 11-01-2009, 12:02 PM
Jakegday Re: Bad mpg 11-01-2009, 06:55 PM
matt5112 Re: Bad mpg 11-01-2009, 08:18 PM
toby Re: Bad mpg 11-01-2009, 08:59 PM
matt5112 Re: Bad mpg 11-01-2009, 01:10 PM
toby Re: Bad mpg 11-01-2009, 01:28 PM
matt5112 Re: Bad mpg 11-01-2009, 08:17 PM
Pittman06 Re: Bad mpg 11-01-2009, 09:14 PM
TheOtherNick Re: Bad mpg 11-01-2009, 09:14 PM
Pittman06 Re: Bad mpg 11-01-2009, 09:15 PM
toby Re: Bad mpg 11-01-2009, 09:30 PM
Pittman06 Re: Bad mpg 11-01-2009, 09:31 PM
cerick08GP Re: Bad mpg 11-02-2009, 08:55 AM
toby Re: Bad mpg 11-02-2009, 02:15 PM
toby Re: Bad mpg 11-08-2009, 06:52 PM
gtpman Re: Bad mpg 11-08-2009, 07:00 PM
  1. #1 Bad mpg
    ohio
    I have a 97 grand prix with 136 mile with a 3800.I am getting 12-14 mpg in town I have put new plug and wire and a new fuel pump and fuel filter 800 miles a go.All fuel pressure are good And some times it crank 5-6 times before it starts No CEL come up beside that it run good. new o2 sensor and cat is good. thank you
  2. #2 Re: Bad mpg
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    n/a or s/c?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: Bad mpg
    When you say new cat/o2, is that front o2 or rear?
  4. #4 Re: Bad mpg
    ohio
    It is naturaly aspirated and new front and back o2 sensor
  5. #5 Re: Bad mpg
    Norristown, PA
    change the air filter?
  6. #6 Re: Bad mpg
    ohio
    done it
  7. #7 Re: Bad mpg
    ohio
    could my lower intake manifold gasket be bad the upper intake manifold plenum and gasket was replace no lost of coolant that i can See or sweet odor
  8. #8 Re: Bad mpg
    ohio
    I need help 12-14 mpg
  9. #9 Re: Bad mpg
    do you KNOW the cat is good? Changing the PCV valve might help.
    On average, whats the highest RPM the engine revs to in first gear?
  10. #10 Re: Bad mpg
    ohio
    The cat is good and pcv was done at tune up. 700-800 hundred in 1st. 1800 hundred at 60 mph could my trouble be my drive to work is 2 to 3 miles every day?
  11. #11 Re: Bad mpg
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by toby View Post
    yes, turning your engine on and off every 2-3 miles will certainly affect your mileage in a negative way. thats also not all that good for your engine..... you should at least let your engine get all the way up to temp at least once a day (assuming you drive it everyday), otherwise the moisture that gets in your oil overnight never has a chance to burn away.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  12. #12 Re: Bad mpg
    Quote Originally Posted by Jakegday View Post
    Theres a reason cars with mostly highway miles tend to drive better after a hundred thousand or so.
  13. #13 Re: Bad mpg
    ohio
    I will get that rpm tomorrow. Is there something i can do for my car because of my 2-3 mile drive to work beside walking to help with mpg thank you
  14. #14 Re: Bad mpg
    Sorry man, i need some punctuation in there to understand all that.
    What I mean is when the car is accelerating what is the highest RPM the engine gets to?
    Also if you're just stopping every time you get up to speed, you'll have crappy mileage just like you're reporting.
  15. #15 Re: Bad mpg
    ohio
    the highest rpm before shifting into 2nd
  16. #16 Re: Bad mpg
    and what is that rpm reading before shifting into second?
  17. #17 Re: Bad mpg
    Wooster, Ohio
    ride a moped? Buy a 80's civic. Short drives like that will kill anything but bullet proof tiny 4 poppers. Try the old slowly run a can of seafoam through your vacuum lines to clean some carbon out trick. Lucas fuel system cleaner maybe, take it out and run the crap out of it once a week maybe
  18. #18 Re: Bad mpg
    Charles City, IA
    No. You wont get good mileage driving 2miles at a time. I would get a moped too.
    SMGPFC Two Nipple General
  19. #19 Re: Bad mpg
    Wooster, Ohio
    btw, where are you at in the ole OH-IO
  20. #20 Re: Bad mpg
    ohio
    I have a 06 harley to ride some days but the zanesville ohio winter are cold
bad, mpg
