Thread: Naturally aspirated benefits with high octane gas?
Results 1 to 20 of 21
  1. #1 Naturally aspirated benefits with high octane gas?
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    hey sorry if this is posted somewhere else, if it has i havent found it. I have a GT with K&N FIPK CAI, and magnaflow mufflers. My car is naturally aspirated, i have no turbo or supercharger with a stock PCM. It says to run my car on regular octane. Would i see any benafits at all if i go to premium? would i get a few extra hp?? or would it just rape my car? thanks guys.
  2. #2 Re: Naturally aspirated benefits with high octane gas?
    Portland Oregon
    No added benefit with an N/A application. I had a cammed L36 with full exhaust, intake, hv3, and ported heads and I decided to get a 5 gal can of 104 octane unleaded and it did absolutely nothing for my times.
  3. #3 Re: Naturally aspirated benefits with high octane gas?
    yeah, your car wont knock as much which means it will run better. anyone that says you dont need high octane on a car that you drive hard is an idiot.
  4. #4 Re: Naturally aspirated benefits with high octane gas?
    Don't need high octane on a Yaris
  5. #5 Re: Naturally aspirated benefits with high octane gas?
    ......you....
  6. #6 Re: Naturally aspirated benefits with high octane gas?
    ......you....
    YES!!
    I win.
  7. #7 Re: Naturally aspirated benefits with high octane gas?
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    YES!!
    I win.
    LMAO
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  8. #8 Re: Naturally aspirated benefits with high octane gas?
    Apr 2009
    Georgia
    oh and i run 93 in my car all the time. and i have even since before the ****ty zzp tune.
  9. #9 Re: Naturally aspirated benefits with high octane gas?
    canada
    In my opinion, unless it is tuned and raced use what the manufacturer calls for. It may seem a surprise to many, but the manufacturers do spend lots of time developing their vehicles, if they say use 89, 91, 93, 105 oct then why mess with something engineared for that type of fuel. I know many will say the manufacturer has no idea what there doing and they know how to make and run a vehicle better, but for my money I just stick to what the owners manual says. My 2 cents worth take what u want from it
  10. #10 Re: Naturally aspirated benefits with high octane gas?
    Quote Originally Posted by echarleswhyte View Post
    have you scanned a bone stock GT lately? they knock from the factory, especially when you run them on 89.
  11. #11 Re: Naturally aspirated benefits with high octane gas?
    Charles City, IA
    If you are going to beat on it run premium. If not run 87.
    SMGPFC Two Nipple General
  12. #12 Re: Naturally aspirated benefits with high octane gas?
    don't it burn better and not clog your injectors as much with premi?
  13. #13 Re: Naturally aspirated benefits with high octane gas?
    Charles City, IA
    Premium burns slower so will will get worse mileage. The only reason it helps your injectors is that premium usually has more detergents in it.
  14. #14 Re: Naturally aspirated benefits with high octane gas?
    Premium should be burning quicker to produce more power.
    With premium you can get better timing which actually increases fuel economy as well.
  15. #15 Re: Naturally aspirated benefits with high octane gas?
    Charles City, IA
    What out raising timing you will get worse mileage it is a proven fact.
  16. #16 Re: Naturally aspirated benefits with high octane gas?
    Facts don't start with questions and end with statements. I HAZ CONFUSE!
  17. #17 Re: Naturally aspirated benefits with high octane gas?
    SE Level Member Boostd1's Avatar
    Thornton, Colorado
    I think that's what he is getting at...you can run more timing with higher octane. Alot of newer vehicles have sensors that detect the octane rating and adjust spark accordingly.
    "The only sustainable competitive advantage is the ability to learn faster than the competition."
  18. #18 Re: Naturally aspirated benefits with high octane gas?
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    My view of the octane debate used to be run what the owners manual said, my 01 4 cylinder ford ranger had no performance improvement with 93 octane over 87 and the mileage remained at 25 mpg.
    Though Bio had me thinking and put 93 octane in my bone stock GT this week and my mileage went from 18 to 21 mpg with my usual city driving. Since I don't have a scanner I can't test myself but when (low rpms?) and why does a stock L36 knock? Is it the compression of these motors compared to others?
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  19. #19 Re: Naturally aspirated benefits with high octane gas?
    Hoffman/Schaumburg, IL
    They all knock from the factory, has a Stock L36 ever chipped a piston running 87 probably 10 or 20 out of the millions of L36's out there....Stock car, Stock tune, run 87..... If 93 makes you feel more comfortable though, I guess the extra 2 bux a fill up is worth it
  20. #20 Re: Naturally aspirated benefits with high octane gas?
    Moore, Oklahoma
    A modded L26 or L36, Especially one with a PCM Tune SHOULD be running at least 91-93 octane. Especially since the timing will be a bit higher than stock, which is the main reason why a tune make more power on those motors, it all in the timing....
    Shawn W. Larsen
  1. What Octane gas to use?!!!
    By Redbirds2230 in forum General Tech Discussion
    Last Post: 10-27-2009, 03:55 AM
  2. How much octane booster?
    By Sabrewings in forum General Tech Discussion
    Last Post: 08-18-2009, 11:19 PM
  3. benefits of blocked egr?
    By 99prixgt in forum General Tech Discussion
    Last Post: 04-12-2009, 04:03 PM
  4. Octane
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-18-2009, 10:20 AM
  5. 98 GT Gas Octane?
    By Shingen in forum General Tech Discussion
    Last Post: 01-30-2009, 05:49 AM
