Ok, so I just got my GTP almost 2 weeks ago and the headlights have not been working right. Occasionally durring the day the DRLs come on. Sometimes when you start the car and the DRLs don't come on, you select high beam and the high beam comes on. Ever since I bought the car I have never had headlights in the dark. The foglights work all the time. The interior lights work all the time. I have replaced the headlight switch with a used unit from the junkyard and didn't work. I've checked the fuses and the circuit breaker next to the glove box. I also looked at the DRL diode under the dash and that seems to look ok. I have also looked at the bulbs and stuff and they look just fine. And to verify that they were not the problem i used a voltmeter to check the voltage at the plug and there was no voltage at the plug. ANY help that anyone can give me or where i should look next would be great!!!
