Thread: BIG headlight problem, need help!!!
Results 1 to 2 of 2
IndyGTP BIG headlight problem, need... 11-05-2009, 01:13 PM
musiknjoyr Re: BIG headlight problem,... 11-05-2009, 03:16 PM
  1. #1 BIG headlight problem, need help!!!
    Indianapolis
    Ok, so I just got my GTP almost 2 weeks ago and the headlights have not been working right. Occasionally durring the day the DRLs come on. Sometimes when you start the car and the DRLs don't come on, you select high beam and the high beam comes on. Ever since I bought the car I have never had headlights in the dark. The foglights work all the time. The interior lights work all the time. I have replaced the headlight switch with a used unit from the junkyard and didn't work. I've checked the fuses and the circuit breaker next to the glove box. I also looked at the DRL diode under the dash and that seems to look ok. I have also looked at the bulbs and stuff and they look just fine. And to verify that they were not the problem i used a voltmeter to check the voltage at the plug and there was no voltage at the plug. ANY help that anyone can give me or where i should look next would be great!!!
  2. #2 Re: BIG headlight problem, need help!!!
    SE Level Member musiknjoyr's Avatar
    Feb 2009
    decatur, al
    try this it worked for me, disonnect the drl's and see if that fixes it. with me i have the ability to see that i need headlights if its raining and can turn them on, but the auto's still work fine. that fixed mine. plus it doesnt annoy me now seeing my reflection in ppls bumpers.
  1. Headlight/electrical problem
    By skunktriscuit in forum General Tech Discussion
    Last Post: 08-28-2010, 02:55 AM
  2. Need HID Headlight help
    By TooMch in forum Audio, Security & Visual Electronics
    Last Post: 11-06-2009, 11:37 AM
  3. New headlight help
    By betsgtp in forum Visual/Body Modifications
    Last Post: 10-19-2009, 07:47 AM
  4. headlight/fog problem
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2009, 09:29 PM
