On a '02 GP N/A, are you supposed to add coolant to the overflow tank or to the radiator directly? I was always taught that you added to the overflow tank and when the radiator was low, it would suck the coolant back up into the radiator. Mine doesn't seem to be doing this. My radiator was low but my overflow tank had plenty of coolant in it. Is this normal? Also, I have noticed that when my engine is dead cold and if I quickly squeeze the upper radiator hose, the coolant sloshes up and down in the overflow tank. It seems like the radiator cap should only open up to the overflow tank when the pressure reaches the rating of the cap. Is my radiator cap bad?
