Thread: Airbag removal and installation
Results 1 to 11 of 11
  1. #1 Airbag removal and installation
    Nov 2009
    Walker, IA
    I tried searching with no luck but may have not been using the right words.
    Anyway I bought a 98 GTP for cheap. Previous owner hit a deer and damaged the passenger fender and door and also set off the air bags. I will be getting a new fender and replacement door and already have the replacements air bags.
    I would like to get the driver side airbag in place. Not to worried about the passenger side since no one rides in the car anyway as its my DD to work. Now I tried getting the air bag off the steering wheel with no luck. I see its held on with 4 metal studs or so it appears by looking at the replacement bag. So essentially I'm stuck here. How do I get the old one off and the new one on?
    Also I just unhooked the battery and waited an hour before messing with the car, is their anything else I need to do to safely remove and replace the bag? And do I need to check any sensors in the fenders to make sure they dont redeploy the bag until I get the fender replaced? I'll be waiting until spring for the body repairs since winter seems like a popular season for body damage.
  2. #2 Re: Airbag removal and installation
    Guam
    There should be bolts behind the steering wheel. Did you remove those?
    It comes out as one, with the horn pad.
    I would have to look to be sure, but normally there is a crash sensor in the front.
  3. #3 Re: Airbag removal and installation
    Nov 2009
    Walker, IA
    I didnt see any bolts, guess I may not be looking hard enough. Also The plastic piece behind the wheel is loose and able to be moved if thats the piece with the screws. I'll go check right now though and see if I missed those.
  4. #4 Re: Airbag removal and installation
    Banned - Busted For Scamming
    Feb 2009
    The air bag has 4 studs with nuts that hold it in. You can take the nuts off from the rear of the steering wheel, they are 10mm head.
  5. #5 Re: Airbag removal and installation
    Nov 2009
    Walker, IA
    Sorry to bring this back up but I just got around to getting back to replacing this air bag and I have the cover behing the steering wheel unbolted and I try to pry it back so find these nuts but all I see is a white plastic peice over the studs and I cant get that to move. Also the studs are smooth with no threads but have a peice cut out towards the end like something is to grab it. Sorry I dont know how to explain better. But I have the replacement airbag I can take a picture of to show what I am talking about if necessary. Am I just missing something here?
  6. #6 Re: Airbag removal and installation
    GT Level Member sic6's Avatar
    san marcos, tx
    Did you already replace your front airbag sensor? And i think you also have to replace the module as well.
  7. #7 Re: Airbag removal and installation
    Apr 2011
    Pittsburgh
    I took off the two back screws for the air bag and I am having the same problem, the air bag wont come off. Is there something else I have to take off? The manual says take the two screws off then the air bag should come out. But it has the same four bolts that
    mach158
    was taking about.
  8. #8 Re: Airbag removal and installation
    Waukesha, WI
    springs?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: Airbag removal and installation
    Apr 2011
    Pittsburgh
    They have little springs on them. A piece of plastic then springs.
  10. #10 Re: Airbag removal and installation
    Waukesha, WI
    hmm google GM air bag tool
    RayRay
    92 Turbo miata
    02 lexus is300
  11. #11 Re: Airbag removal and installation
    Apr 2011
    Pittsburgh
    I found out that there are 4 screws that are held on by a metal bar. If you take a flat head screw driver and seperate it from the screws the one side should come up. Same with the other side.
  1. Airbag turns off & on
    By summersGT in forum General Tech Discussion
    Last Post: 10-15-2009, 12:18 PM
  2. srs airbag
    By pacothetaco in forum General Tech Discussion
    Last Post: 08-02-2009, 11:13 PM
  3. airbag/compass
    By Clar2478 in forum General Tech Discussion
    Last Post: 01-13-2009, 01:06 AM
  4. Steering Wheel Removal & Installation
    By $03gp/gt$ in forum General Tech Discussion
    Last Post: 12-14-2008, 07:38 PM
  5. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
