Thread: Freeze frame, what does all this mean?
Results 1 to 8 of 8
  1. #1
    Donating Users khung88876's Avatar
    Apr 2011
    Pekin IL
    Closed
  2. #2 Re: Freeze frame, what does all this mean?
    -21 is technically outside of the -16.4 to 16.4 range for LTFT's....
    So it seems the car is detecting way too much fuel and attempting to reduce it.
    LTFT's should be around -3 to 3 most of the time.
    Also appears this was at idle according to the vec speed....
    TPS is 20.7% or what?
    Can you get the voltage for the TPS?
    It should be .40 V at no throttle.
  3. #3 Re: Freeze frame, what does all this mean?
    get a digital multimeter...
    also sort out those codes.
    theres info on that in the FAQ section at the top of every page.
  4. #4 Re: Freeze frame, what does all this mean?
    if thats 20.7% TPS then yes, get a new TPS sensor.
    Its on the side of the TB.
  5. #5 Re: Freeze frame, what does all this mean?
    Honestly? no idea.
    Try going to GPONA.com and looking in the GM service manual OR try compnine.com and looking under diagrams/research.
  6. #6 Re: Freeze frame, what does all this mean?
    Kansas
    There is an additional fail-safe APS but 99.9999999% chance that theres nothing wrong with it. As for the user APS, it is the whole accelerate pedal itself. I just replaced mine here a few months ago due to erratic idles while moving. And IIRC there is two bolts holding it on.
  7. #7 Re: Freeze frame, what does all this mean?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    -21 is the Evap purging no worries. Whats the TPS reading at idle?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Freeze frame, what does all this mean?
    Kansas
    The problems I was having with mine was cruising down the highway at idle, my RPMs would fluctuate, service bulletin said APS could be the cause. Replaced APS, same problem, tranny warrantied.
  1. Changing Freeze Plugs
    By tmackster in forum General Tech Discussion
    Last Post: 02-06-2011, 11:44 PM
  2. Anti Freeze Leak
    By JB381 in forum General Tech Discussion
    Last Post: 02-26-2010, 09:00 PM
  3. 06 gp frame flex??
    By reallyfast1 in forum 04+ Specifics
    Last Post: 09-12-2009, 09:18 PM
  4. what frame
    By TheGreatSamG in forum General Tech Discussion
    Last Post: 03-10-2009, 12:09 PM
  5. sub frame
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2008, 02:48 PM
