Thread: Power Steering WORKOUT!
Results 1 to 7 of 7
  1. #1 Power Steering WORKOUT!
    SE Level Member bmount01's Avatar
    Bristol, VT
    Does anyone know of a problem with the steering system which only affects one way (left and not the other (right)? My problem is the steering on the '01 GTP. When turning to the left, the assist cuts out and it is very difficult to turn. THis is both when stopped and at varying speeds. Turning right is no problem. What is the deal? How do I fix it?
    Thanks!
    Bill Mount
    Bristol, VT
  2. #2 Re: Power Steering WORKOUT!
    Guam
    Check your fluid, but I doubt that is it...
    You need an entire new steering rack to fix this. It will eventually get worse and the assist will all together stop one day.
  3. #3 Re: Power Steering WORKOUT!
    PA
    Quote Originally Posted by toolguy View Post
    I agree. Most likely you have a bad steering rack. But check the fluid first and make sure it is up to the correct level. Other than that, start thinking about replacing the steering rack.
    2001 GSE
  4. #4 Re: Power Steering WORKOUT!
    GT Level Member skidoojames151's Avatar
    seattle
    any weird sounds like whining from the P/S?
  5. #5 Re: Power Steering WORKOUT!
    tj
    you will need a steering rack i have the same prob..suckss
  6. #6 Re: Power Steering WORKOUT!
    Bristol, VT
    Correct me if I am wrong but it sounds like you are thinking it may be the STEERING RACK! (ha) I thought so but I didn't know without prodding around if there were a repair or if replacement was necessary. Bummer... Thanks all! Anyone want a 2001 Pontiac Exercise Machine?
  7. #7 Re: Power Steering WORKOUT!
    PA
    Quote Originally Posted by bmount01 View Post
    There isn't really any repair for the rack. You just need a new one and replace the entire unit.
    If you were closer, I would take you up on your offer.
    2001 GSE
  1. Power Steering
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2009, 11:51 PM
  2. power steering
    By thelost1123 in forum Engine
    Last Post: 06-07-2009, 10:47 PM
  3. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
  4. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
