Thread: HELP! Overheats at idle
Results 1 to 12 of 12
  1. #1 HELP! Overheats at idle
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    So i get home friday and i noticed the car was really hot, around 230 degrees...i was low on coolant, so i filled it. Then we started it and nothing, so i replaced the t-stat, which was broken btw. So now the car runs ok but when it idles it starts to heat up rapidly. As soon as i start driving it cools down rapidly...im confused. Also that same day i noticed i cant put the shifter into d or anything. Its stuck in park so i have to push down the shift lock...also, it doesnt show on my gauge cluster that im in d or p or anything else. (ya know the little red dot that shows up, ya its not there..) any ideas??
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  2. #2 Re: HELP! Overheats at idle
    GTX Level Member cerick08GP's Avatar
    The first thing I would check is if the radiator fans are running. If they aren’t, turn on your AC that will force one on. If the temp goes down, there is your problem.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: HELP! Overheats at idle
    Reading, PA
    I dont think they are and thanks ill try that
  4. #4 Re: HELP! Overheats at idle
    May 2008
    McHenry IL
    check to see if you have air in your system that was my problem
  5. #5 Re: HELP! Overheats at idle
    Guam
    Yes, did you make sure and bleed the system after th T-stat was replaced?
  6. #6 Re: HELP! Overheats at idle
    PA
    Sounds like you are probably losing coolant somewhere. If you never replaced the LIM gaskets, I would consider doing that.
    But the coolant that you are losing (if has to be going somewhere if it was low) got low enough to make the car heat up. When you added fluid, did you add it to the radiator? You should be adding it directly to the radiator, not the overflow tank. The overflow tank is just to catch the overflow. Remove the radiator cap and make sure the radiator is full to the very top.
    After everything is full, make sure you have the system bled properly. Any air in the system can cause it to overheat.
    Also, if you have not replaced the radiator cap recently, make sure you do that as well, as a bad cap can cause these issues.
    2001 GSE
  7. #7 Re: HELP! Overheats at idle
    Reading, PA
    We correctly bled the system, but today I found out a ground wire was messed up :/ easy fix tho now she runs normal!
  8. #8 Re: HELP! Overheats at idle
    So was that causing the fans not to run?
    2008GP
    2002GP||sold
  9. #9 Re: HELP! Overheats at idle
    Reading, PA
    Ya the wire was the one controling the fans
  10. #10 Re: HELP! Overheats at idle
    Guam
    Cool! Glad you found it!
  11. #11 Re: HELP! Overheats at idle
    Sweet, I totally called that one These GP fans are sneaky
    2008GP
    2002GP||sold
  12. #12 Re: HELP! Overheats at idle
    Reading, PA
    Ya haha I'm happy
  1. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
  2. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  3. Rough Idle
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 02:39 PM
  4. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  5. vacuum at idle?
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 06:37 PM
