Thread: DIC question
Results 1 to 10 of 10
  1. #1 DIC question
    Greetings all,
    The DIC in my 2002 GTP started doing something strange two days ago. The display will intermittently get bright and then return to normal. No other lights or the HUD are affected. When it goes bright. the lamps in the three buttons on the left as well as the traction lamp will go out.
    Was wondering if this could be the back-light bulbs or the display itself.
    Also, is it hard to get at. I've been searching the forum but only found one post as to how to get in there.
    Thanks in advance.
  2. #2 Re: DIC question
    PA
    Quote Originally Posted by airhead View Post
    Greetings all,
    Thanks in advance.
    Yes, the bulbs can go bad. But I read a thread over at CGP about the solder joints going bad in these. Could be your issue. If I were you, I would take the DIC apart, check all the solder joint, re-solder any that need it, and replace any bulbs that are bad. Should fix your issues.
    2001 GSE
  3. #3 Re: DIC question
    Thanks for the reply. Much appreciated.
  4. #4 Re: DIC question
    Outer Space
    If you need another GTP DIC, let me know. I bought an extra one a while back.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: DIC question
    GT Level Member skidoojames151's Avatar
    seattle
    what year is it out of?
  6. #6 Re: DIC question
    For Zef_66,
    I was at CGP as well but my searches didn't find the sodler joint post. Could you direct me?
    Thanks again. Airhead
  7. #7 Re: DIC question
    PA
    This is how to change the bulbs:
    Link
    I don't have a link to the post about bad solder joints. But the above shows you how to get the DIC apart. Just look and double check all the solder joints. And use a magnifying glass and really good light. Cracked joints can be really hard to see sometimes.
    2001 GSE
  8. #8 Re: DIC question
    Thanks Zef. Much appreciated.
    Airhead
  9. #9 Re: DIC question
    Outer Space
    Quote Originally Posted by skidoojames151 View Post
    Im not exactly sure, I bought it from Morad for my 2002 GTP. Never hooked it up.
    I can send you a pic if needed.
  10. #10 Re: DIC question
    seattle
    pm sent
  1. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  2. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
