mod list is in sig...how much of a diff am i gonna feel if i put in 1.9 YT roller rockers?
if i go 1.95 can i still use ls6 or l76 springs? or do i need comp 105's?
you'll feel a difference in the upper rpm range, id like to say around 4k, the idle changes slightly too.
will it be a wow that 500$ was worth it diff? hahaha
Nope. I don't get why people spend so much on rocker setups. Get modded stock rockers used. Prices have gone down it seems since I bought mine. I've seen $200 sets for sale recently. I, along with many others, just run the stock springs with 1.9 modded stock rockers without issue. It is a good mod but not $500 good. $200 - $250? Now we're talkin'. No need to worry about aftermarket rocker problems (e.g. Intense) or springs breaking (e.g. Comp Cams) going with modded stock rockers and stock springs not to mention its cheaper and quicker to install.
I got my rockers that had 500 miles on them for $150. ZZP modded ones and they work good and i definitely feel it complemented the 3.4 pulley.
i second the modded rockers, having said that i got a screaming deal on my springs so i did them, but if they werent free, i wouldnt have.
Look for them used, modified or just used. Personally I'd prefer spending an extra $20 for rollers instead of modded. I've seen prices on both being about the same for a while now.
You'll feel the difference, especially being that you have the pulley and need more flow through the heads.
i loved the feel of my ZZP ER rockers (the split ratio) on my L36 i didnt like the idea that some guy spot welded them and re drilled a hole. after i popped #4 i sold the rockers and bought the 1.8 yella terra (zzp rollers) my car still pulls. for the over 500$ you are going to spend on 1.95's and springs id go with a cam
^^Exactly...hence why for $500 you can almost do a cam...if not doable.
I'm trying to pick my next mod for the spring, either rockers, a cam, or headers, so LMK how it turns out.
Eh id do intercooler but thats just me, im bout to make a new aluminum design so ill let everyone know how that turns out.
