Thread: Procedure to program the BCM
Results 1 to 8 of 8
  1. #1 Procedure to program the BCM
    Tennessee
    I have to replace the Body Control Module on my wife's 2001 Prontiac Grand Prix SE due to issues with the DTR lights, A/C fan, and driver information center delays at startup.
    Anyway, I understand that the unit needs to be reprogrammed after replacement. Can anyone explain the procedure to me.
    Thanks in advance.
    Darin
  2. #2 Re: Procedure to program the BCM
  3. #3 Re: Procedure to program the BCM
    Milwaukee,WI
    You sure it's the bcm? I had the same issues, and it was the fan ignition switch... http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
  4. #4 Re: Procedure to program the BCM
    MO
    it should just be plug and play.
    Wrong? Your BCM is also what has the VIN, mileage, etc... all that computer stuff in it. When I got mine fixed I had a reputable auto electric place diagnose it and they sent me to the dealer saying only the dealer could reprogram it.
    <brandonl2000> LMAO D!!
  5. #5 Re: Procedure to program the BCM
    Tennessee
    I am not sure it is the BCM.. but with the fan, Daytime running lights, Driver information crap, and fan all starting at the same time, looking at the wiring diagram in the Chilton's manual, and looking at other entries in the thread I thought it was the only answer..
    Now I am not sure... CRAP...
    It could be the ignition switch I guess, She has had the key stuck problem also, which I just learned in the forum that I can yank out a solenoid to correct that issue. I am not sure if they could be related.
    Not sure where to start now.. Replacing the BCM seems easier now, assuming there is no programming which I saw was required somewhere, not sure if it is just for the key fobs or if the BCM is replaced..
    I am freaking lost again...
    Ugg...
  6. #6 Re: Procedure to program the BCM
    you dont need everything to match. the car will still run. i didnt have the correct VIN in my PCM ever.
  7. #7 Re: Procedure to program the BCM
    Guam
    The only programming I saw was for the door locks, interior lights and settings like those. All stufff that the owners manual tells you how to program.
    You can enter this mode to kind fo test to see if the BCM is working. It is not a 100% real test, but still a test.
  8. #8 Re: Procedure to program the BCM
    MO
    they also had to program it to recognize my remotes too. Keep in mind this is on a blazer, but it's essentially the same thing
  1. Does anyone know how to program keyless remotes?
    By green/blue05GT in forum 04+ Specifics
    Last Post: 01-20-2010, 09:36 PM
  2. Procedure for changing diff while in the car.
    By machine head in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2009, 03:15 PM
  3. Adjustment procedure for shifter cable?
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-30-2008, 09:43 PM
  4. can anybody help me program my pcm
    By shawn in forum PCM Tuning
    Last Post: 08-09-2008, 11:51 AM
  5. program a fob??
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 07-07-2008, 10:22 AM
