Thread: Coolant Flush : How to?
Results 1 to 7 of 7
  1. #1 Coolant Flush : How to?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    My Dex-Cool is ready to be replaced. I'm actually getting a buildup of some brown crap all over the inside of the coolant bottle. I head that its pretty easy to do a coolant flush yourself. So basically I can ramp up the front of the car, locate the plug on the bottom of the radiator, unhook it and let all the fluid drain into a pan or 2. Then I can take the plastic bottle out of my car and clean that out. Then I can just hook the bottle back up, put the plug back in and refill the coolant? Is that it or do I need to run something else through the system before I add new stuff in?
    My friend, who is a mechanic at a dodge dealership said he would give me a coolant flush for 70$. Seems kinda high but he said he would back flush the coolant through the heater core. What do you guys think about backflushing coolant through the heater core?
    Thanks.
  2. #2 Re: Coolant Flush : How to?
    Oklahoma
    While in most cases I am a huge voice for doing it yourself, the cooling system is something that having it professionally done is worth it in the long run. And that is simply because of the time that it takes and the fact a professional flush can do a much better job in cleaning out that gunk you speak of.
    I have done coolant flushes myself and the heat up and cool down cycles are time consuming, you need to drain the radiator, pull the lower hose and pull out the front knock sensor to make sure your getting as much out as you can, then you have to repeat all that a few times to get it done right.
    A professional flush can be done with the engine running and they do a good job of cleaning out the system. $70 is a pretty decent price for it being done at a dealership. I had mine professionally flushed and I think I paid $85 and that wasnt at a dealership and if he can back flush it and clean out the heater core, I think that is a decent deal.
  3. #3 Re: Coolant Flush : How to?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I agree with Scotty here. However IF you decide you want to try it yourself here is a link to one write-up...Although I believe I've seen a more detailed write-up elsewhere ClubGP:
    Here is a way more detailed write-up from one of the guys over at newimpala.com
    Important
    Do not use a chemical flush.
    Store used coolant in a properly labeled container. Do not pour used coolant down a drain. Ethylene glycol antifreeze is a very toxic chemical. Do not dispose of coolant into the sewer system or ground water. This is illegal and ecologically unsound.
    Various methods and equipment can be used to flush the cooling system. If special equipment is used, such as a back flusher, follow the manufacturer's instruction.
    When the cooling system becomes contaminated, the cooling system should be flushed thoroughly to remove the contaminants before the engine is seriously damaged.
    Drain the cooling system. Refer to Draining and Filling Cooling System .
    Remove the coolant recovery reservoir. Refer to Coolant Recovery Reservoir Replacement .
    Clean and flush the coolant recovery reservoir with clean, drinkable water.
    Install the coolant recovery reservoir. Refer to Coolant Recovery Reservoir Replacement .
    Follow the drain and fill procedure using only clean, drinkable water. Refer to Draining and Filling Cooling System .
    Run the engine for 20 minutes.
    Stop the engine.
    Repeat the procedure if necessary, until the fluid is nearly colorless.
    Fill the cooling system. Refer to Draining and Filling Cooling System .
    Draining Procedure
    Caution
    With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
    Park the vehicle on a level surface.
    Remove the coolant pressure cap.
    Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
    Place a drain pan under the drain (c!!!).
    Open the radiator drain (c!!!).
    If a complete engine block drain is required, remove the engine block drain plug.
    Inspect the coolant.
    Follow the appropriate procedure based on the condition of the coolant.
    Normal in appearance -- follow the filling procedure.
    Discolored -- follow the flush procedure. Refer to Flushing .
    Filling Procedure
    Tools Required
    J 23688 Coolant and Battery Fluid Tester
    Notice
    Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    Close the radiator drain (c!!!). Tighten
    Tighten the radiator drain (c!!!) to 2 N·m (18 lb in).
    If the engine block drain plug was removed, perform the following:
    Apply pipe sealer to the drain plug.
    Install the drain plug. Tighten
    Tighten the drain plug to 22 N·m (16 lb ft).
    Lower the vehicle.
    Open the cooling system bleeder screws.
    Important
    Use a 50/50 mixture of DEX-COOL antifreeze and deionized water.
    Slowly fill the cooling system with a 50/50 coolant mixture.
    Close the cooling system bleeder screws.
    Install the coolant pressure cap.
    Start the engine.
    Run the engine at 2,000 - 2,500 RPM until the engine reaches normal operating temperature.
    Allow the engine to idle for 3 minutes.
    Shut the engine off.
    Allow the engine to cool.
    Top off the coolant as necessary.
    Inspect the concentration of the engine coolant. Using the J 23688 .
    Rinse away any excess coolant from the engine and the engine compartment.
    Inspect the cooling system for leaks.
    Removal Procedure
    Remove the cross vehicle brace. Refer to Brace Replacement - Cross Vehicle in Body Front End.
    Reposition the reservoir hose clamp (1).
    Remove the reservoir hose from the radiator overflow neck.
    Remove the coolant recovery reservoir nuts (2) from the shock tower studs.
    Remove the coolant recovery reservoir (3) from the lower retainer and the shock tower studs .
    Drain the coolant from the recovery reservoir in to a clean container.
    Installation Procedure
    Install the coolant recovery reservoir (3) onto the lower retainer and the shock tower studs.
    Notice
    Install the coolant recovery reservoir nuts (2) to the shock tower studs. Tighten
    Tighten the nuts to 3.3 N·m (29 lb in).
    Lubricate the reservoir hose with clean water. Route the hose to the radiator overflow neck fitting.
    Install the coolant reservoir hose (1) to the overflow neck fitting.
    Install the reservoir hose and clamp (1), with the clamp tabs at the 11 o'clock position, to the radiator overflow fitting on the radiator filler neck. The hose end must be flush against the radiator filler neck. Seat the clamp squarely between the radiator filler neck and the flared end of the fitting.
    Install the cross vehicle brace. Refer to Brace Replacement - Cross Vehicle in Body Front End.
    Fill the coolant recovery reservoir to the proper level.
    Thanks to Bobspala for submitting this
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Coolant Flush : How to?
    Feb 2008
    South Bend, IN
    Thanks for the replies. I will go ahead and have my friend do it for the heater core backwash and peace of mind.
  5. #5 Re: Coolant Flush : How to?
    St Louis MO
    Quote Originally Posted by 04CompG View Post
    Good choice.
    2010 Camaro SS LS3
  6. #6 Re: Coolant Flush : How to?
    Ok Not to say what eveyone else has said is wrong because its Not But here is a Much Much Easier way to fluff your cooling sys...
    1st. Go to your parts store and pick up a bottle of Zerex Cooling sys Flush, Prestone flush kit, a new thermostate/gasket and some antifreeze.
    2nd. Go home take your Thermostate out and replace thermostate housing it will be ok if it leaks alittle.
    3rd Cut your heater hose just before it enter's the firewall and intall the coupler that comes with the prestone flush kit make sure you cut the hose that FLOWS into the heater core, just read the direction that comes in the kit.
    4th pour the Zerex cooling sys flush in the radiator and let the engine run for 10 to 15 min... Then let cool..
    5th After letting the sys cool contect your garden hose to the fitting you installed in your heater hose, take your radiator cap off and turn on your garden hose, start the motor and turn the heater on HIGH run the motor with your hose on high till clear water flows from your radiator, after that happen turn off the engine and hose.
    6th Take off your lower Radiator hose and empty the sys, replace the thermostate with your the new one and a new Gasket.
    7th Refill your sys and leaving the cap off of the fitting you installed in the heater hose, when coolent flows from there just place the cap on the fitting top off the radiator and start engine and check for leaks... Just check the coolant leave and fill as needed...
    Hope that helps
  7. #7 Re: Coolant Flush : How to?
    St Louis MO
    Thanks for your write-up as well. While similar to the link from CGP it is a nice addition with a few more details.
    2010 Camaro SS LS3
  1. how to flush mount your remote bass knob and an led [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 11-19-2009, 10:14 PM
  2. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  3. dexcool coolant
    By stoney81ta in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 09:12 AM
  4. Going to vip for a coolant flush
    Last Post: 03-12-2008, 03:42 AM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
