Thread: 07 Grand Prix - Rear defroster messes up radio
Results 1 to 2 of 2
  1. #1 07 Grand Prix - Rear defroster messes up radio
    WI
    I have an 2007 Grand Prix that I recently purchased. Whenever I turn on the rear window defroster I lose all radio reception. I have read some technical service bulletins on older years related to this but not for the 2007. The rear defroster works fine. The radio works fine when the rear defroster is off. Has anyone else had this issue and if so how did you fix it?
    Thanks in advance.
  2. #2 Re: 07 Grand Prix - Rear defroster messes up radio
    Wausau, WI
    are they both grounded properly? Not sure, but if the lines run next to each other you may have to insulate one of them if the grounds check out OK...Not 100% sure though
  1. 2006 Grand Prix CB Radio Install
    By novacoke in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 10:01 AM
  2. 01 grand prix gt radio mod
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2009, 12:09 PM
  3. 99 grand prix rear bearings
    By kevinc2187 in forum Brakes/Suspension/Chassis
    Last Post: 06-19-2009, 10:34 AM
  4. 2002 grand prix radio wiring
    By NEONNIGHT34609 in forum Audio, Security & Visual Electronics
    Last Post: 03-23-2009, 07:37 PM
