Thread: No Heat!
Results 1 to 6 of 6
  1. #1 No Heat!
    PA
    Hi Everyone,
    I have a problem with my 03' Grand P., GT. There is no heat!
    The blower works, I can hear the vacuum hoses working when I use the selector, A/C works. No coolant inside on the floor. Has anyone had this problem, can I fix it myself?
    Thanks in advance for your help!
    Scott
  2. #2 Re: No Heat!
    GTX Level Member cerick08GP's Avatar
    Nope I never have had this problem.
    Check your radiator coolant level, when the engine is cool. Your radiator should be basically completely full. If not add Dexicool, if you’re in a pinch you can add distilled water. Just check the freezing point ASAP afterward.
    If your level is good, get back to us.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: No Heat!
    PA
    Ya see?!
    This is why I joined this forum! I have had great advice on another forum ( CRX) and this forum is no different.
    cerick08GP, you were right, so far. I had not filled the system enough! The heat is working.
    Thanks much.
    Scott
  4. #4 Re: No Heat!
    Glad I could help
    2008GP
    2002GP||sold
  5. #5 Re: No Heat!
    Donating Users mystic231's Avatar
    Michigan
    If you were that low on coolant remember to purge the air out of the system, especially if you're still running DexCool.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  6. #6 Re: No Heat!
    PA
    Thanks Mystic.
    Scott
  1. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  2. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
  3. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
  4. Air and heat problems
    By chrizzle17 in forum General Tech Discussion
    Last Post: 12-10-2008, 08:28 PM
  5. Heat Extractors
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-04-2008, 08:08 AM
