Thread: Thats not right...
Results 1 to 4 of 4
  1. #1 Thats not right...
    SE Level Member k5greek's Avatar
    Vineland, NJ
    Ok well a little history on the car. When i first bought it whenever i used the heat or ac it never worked on 1 or 2 but 3 4 and 5 work no problem. Last night i put the heat on and it was on 3 and my headlights turned off I flipped the dial to off and they came back on. I tried putting it on 4 and the same thing happened. This time i tried turning to 5 and headlights came back on and heat was blowing out fine.
    Wtf could be causing the headlights to turn off when i put it to 3 and 4?
  2. #2 Re: Thats not right...
    Wausau, WI
    ignition, it has all sorts of things ran through it. If it was just the fan I would suspect the blower motor resistor, but when many things are involved, often it is the ignition which is bad. Not guaranteed of course, but a place to start.
  3. #3 Re: Thats not right...
    GTX Level Member cerick08GP's Avatar
    x2 on replacing the blower resistor. IMO you have to start there, then seen what happens with your headlights.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Thats not right...
    Charles City, IA
    I say ignition switch due to the headlights.
    SMGPFC Two Nipple General
