Thread: Steering and Shifting Questions
Results 1 to 9 of 9
  1. #1 Steering and Shifting Questions
    SE Level Member jimgs03's Avatar
    Charlotte, NC
    Newbie here with a few questions. First, I have a 2003 Grand Prix SE I bought earlier this year. Only 2 things stand out that I need to address:
    First, when I steer full left I get a scraping/raspy sound from the passenger side firewall. Full right does not do this at all. I'm familiar with hearing sound on other cars when turning to the limits, but this is louder than I'm used to and only when turning left. Any Ideas on what this could be? Or is it common?
    Second is the tranny. She occasionally will slam into first. The car moves slightly, then engages hard. This doesn't always happen, but there's definately an issue here. I did some searching and found that the 4T65E has a common pressure control solenoid issue, but I'd like to get opinions before I go replacing that.
    Any help would be greatly appreciated!
    JG
  2. #2 Re: Steering and Shifting Questions
    Charlotte, NC
    Nobody?
  3. #3 Re: Steering and Shifting Questions
    Donating Users Liquifire's Avatar
    Wausau, WI
    could it be your power steering pump? Have you checked your levels on this lately? Not sure on the tranny at all
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  4. #4 Re: Steering and Shifting Questions
    Charlotte, NC
    The steering and tranny fluids are both topped off properly and the fluids look good. I'm leaning more towards the rack over the pump (Steering) as I'm only getting the sound on a hard left turn. But I hate 'shotgun' troubleshooting. I've got FSM's for my other rides, guess I may have to cough up the $ for GP FSM.
    I appreciate the reply
    JG
  5. #5 Re: Steering and Shifting Questions
    Wausau, WI
    The rack would be a good bet to have gone out. They do go out fairly often on our cars(not nearly as often as MAF and Crank position sensors though) and your logic on the tranny seems like it very well could be. Try posting the tranny question in the tranny section. Usually the trannyman will help out in trying to answer these types of questions, or you could PM him as well if he does not respond to the thread. He is a sponsor on here and builds tranny's that kick but for our cars and last forever. He represents Triple Edge Performance transmission's...good luck. When was the last time that you did a tranny pan drop and replaced the filter?
  6. #6 Re: Steering and Shifting Questions
    Charlotte, NC
    Thanks for the reply Liquifire.
    The tranny fluid and filter were serviced ~March '09, so it's as fresh as a non-flush can be. I'll try posting in the tranny section, I've seen some of Trannyman's responses..sounds like he knows his trade.
    I'll keep my eyes open for a good deal on a steering rack, but no rush. For right now it's a nuisance, but no performance issues evident.
    I do wonder though; I see racks available with ad without 'Variable Effort Steering'. How do I identify whether mine is equipped?
    Thanks - Jim G
  7. #7 Re: Steering and Shifting Questions
    SE Level Member Matt's Avatar
    Indiana
    Look for "NV7" RPO code on the inside of your rear trunk lid. That's the code GM uses for Magnasteer. If it's there, your car has Magnasteer installed.
  8. #8 Re: Steering and Shifting Questions
    Charlotte, NC
    Quote Originally Posted by Matt View Post
    Thanks Matt - Old post or not, still good info. Too bad about your team; great season though
  9. #9 Re: Steering and Shifting Questions
    Uh Matt...it's a little old no?
  1. better shifting?
    By nicksilvergt99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 11:19 PM
  2. rough shifting
    By grandprix85 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 11:52 AM
  3. deck & steering wheel control questions from an idiot
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2008, 09:57 PM
  4. Shifting 1,2,3 before 20 mph!!
    By fratzke7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2008, 06:22 PM
  5. Another shifting from CGP
    By gp2000gt in forum Introductions/Noob Questions
    Last Post: 01-28-2008, 04:07 PM
