ok? dont care about the mileage. I am going to run it for the 103 octane.
saw was your car at nelson tire in charles city like last week?
Is this thread really discussion about using a higher octane in a forced induction car? Get real people...it needs it...like a motor needs oil. You should have known this before you bought the car...*sigh*
E-85 initially takes 30-40% more fuel, but after tuning for it you can gain back some mpg and still are only paying $2 a gallon for 104 octane. There are plenty of high powered forced induction street cars that swear by it and have dyno results to prove the gains. One person hit 430whp on a small turbo kit and stock engine and cam, 1.9 rockers running E85. I can say it kills at least 6-10* of knock.
If I wanted cheap fuel economy I would put 87 octane in and tune for that to run safe, granted I would have to pull about 10 degrees of timing and more, but that would not be fun at all.
I would read the MANUAL and go with what that says. The manual is still a good book to read and get info. I know cars, love them, not saying I'm an expert, but I still read the manual when I get into a diff/new car. One of the first things I do.
i use 93 allllll day every day... Don't starve that beast. Feed her good
Id stick with premium, go with what the manuel says.
MANUAL
is something like this...
http://bcdautoparts.com/images/1998%...s%20manual.gif
MANUEL
On the other hand...is like this...
http://foodcourtlunch.com/wp-content...07/mexican.jpg
Spell check works wonders by the way
Higher Octane Gas = more $ per gallon.
Higher Octane Gas + a car designed for it = better running car.
Better running car = Better gas mileage
Better gas mileage = Less Gas used, offsetting the initial higher gas cost.
17 mpg on cheap gas@ 2.49 gallon, 10 gallons = 6.8 cents/mile running bad
19.1 mpg on BP 92 @ 2.69 gallon, 10 gallons = 7.1 cents/mile running well.
The 4% fuel cost savings isn't worth it. Run the Gas the Car was designed for.
You will get better mileage with the 87 tho. It burns hotter.
http://www.grandprixforums.net/f18/w...here-1507.html
That explains everything to support why you should use the higher octane. plus that informative price breakdown
How about this if you dont run premium I will come to your house and ***** slap you. Problem solved.
