Thread: boost gauge install
Results 1 to 3 of 3
  1. #1 boost gauge install
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    I just bought a sunpro sport st boost gauge and i need to find out which wire for my lighting i need to hook up 2 so the gauge lights up. Any1 have any ideas please let me know. Thanks.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  2. #2 Re: boost gauge install
    Wausau, WI
    isnt there a power wire that should get hooked into the fuse box? with some circuit that has switched power with the ignition? I would think that is where you would want it to go.
  3. #3 Re: boost gauge install
    GEORGIA
    ok, thanks.i found what fuse to do it on.
  1. GOT MY BOOST GAUGE i have some Q's
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 09-29-2009, 10:42 PM
  2. Need a Boost Gauge
    By SDGTP99 in forum General Tech Discussion
    Last Post: 09-27-2009, 08:20 PM
  3. MAP and Boost gauge
    Last Post: 07-02-2009, 12:49 PM
  4. Boost gauge...
    By WayneG99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 08:52 PM
  5. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
