Thread: = => Where do I Refill the TRANSMISSION Oil Help <= =
Results 1 to 20 of 25
  1. #1 = => Where do I Refill the TRANSMISSION Oil Help <= =
    SE Level Member KevSorbo's Avatar
    Socal
    So I conquered changing out the Super Charger Oil and Removing the old Transmission Oil. I dropped the pan and let out about 7.5 QT of old tranny fluid. Replaced the Filter and installed it back. I followed the guide and reinstalled everything correctly. Now I'm stuck on where the oil goes
    I need to add 7.5 QT of Dexon VI Castrol Transmission fluid. Now I have an idea to take a funnel and place it into the Transmission Dip Stick and fill that way. Is that the right way? No one had pics or stated where the transmission oil goes when refilling.]
    I'm almost certain but I don't want to take any risk.
    Please show me a picture or describe where exactly the Transmission Oil goes.
    Thanks.
  2. #2 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Nov 2008
    Searcy,Arkansas
    It goes in the only place it can go....Your right that is where it goes. Also when you get it back in there start the car and let it set for a little bit and while sitting just slowly go threw all the gears about 2-3 times then once it gets good and warm check it to make sure you did add enough.
  3. #3 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Jersey
    just noticed you made 2 of the exact same posts in different sections...lame...
    16' wrx sti- stock
  4. #4 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by 99prixgt View Post
    3....
  5. #5 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Socal
    My bad...I really wanted an answer asap....I've got to leave out for the night and cant leave it where its parked.
    I'm sorry. I was pressed for time.
    thanks for the answer!
  6. #6 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Donating Users Liquifire's Avatar
    Wausau, WI
    next time just put it in the general tech section. That area gets plenty of traffic to resolve any issues you might have in a reasonable amount of time.
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  7. #7 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Donating Users chico's Avatar
    You could always drill a hole in the trans. pan but you would need to flip the car over to filll ,with the hole you drilled just use a big wad of chewing gum to plug it this will make your next fluid change easier!
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  8. #8 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Socal
    Removed by kevin sorbo
  9. #9 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Oct 2008
    Northern Illinois
    Quote Originally Posted by KevSorbo View Post
    Would that be before or after I'm finishing up drilling and flipping your girl? Then I can use the gum to plug it up to keep it minty fresh. Enjoy, as it will make it Easier for YOU next time.
    Really...?
  10. #10 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    LOL
  11. #11 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Wausau, WI
    LOL.....owned.
  12. #12 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Whoa there killer.
  13. #13 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Guam
    LOL!!!!
  14. #14 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Nov 2008
    Searcy,Arkansas
    ewwwwwwww
  15. #15 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    For a gay man in love with Kevin Sorbo I doubt you'd manage ,I'd be suprised if you could find your own butt hole ,were in f--ck do you'd think you'd fill the trans. tuff guy you ask that stupid a question and do'nt expect a bomb .
  16. #16 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Wausau, WI
    Quote Originally Posted by chico View Post
    chico...you are a little late on the comeback. If he is in love with Sorbo, are you in love with a dog? You have had weeks, and this is your comeback? Weak.
  17. #17 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Quote Originally Posted by Liquifire View Post
    It was weak and belated the comeback but because I was amazed the OP was attacking my wife this IMHO is crossing the line and in this case I just do'nt know what to say you see my wife passed away sept.14 from cancer and I have not gotton out of the depressed state of mind,I will say my comments to the OP were a bit tasteless but the comeback was downright vulger and for you to find it funny only shows your level of maturity .
  18. #18 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Oct 2008
    Northern Illinois
    Wow. I'm really sorry to hear that dude. That's terrible.
    I found it pretty immautre and kind of 8th grade in the first place, and after taht too just wow.
  19. #19 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    Wausau, WI
    I truly am sorry for your loss. I only found it funny because it was a reply to your sarcastic comments. I agree he crossed the line, but it was only after your comments. Again, sorry for your loss. Certain things can be funny and be "not right"
  20. #20 Re: = => Where do I Refill the TRANSMISSION Oil Help <= =
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    funny
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  1. = => Where do I Refill the TRANSMISSION Oil Help <= =
    By KevSorbo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2009, 05:11 PM
  2. Transmission
    By joeyt637 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2009, 11:22 AM
  3. transmission
    By jhlbigblock454 in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 02:40 PM
  4. Transmission help.
    By RichCresci in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-03-2008, 03:35 PM
  5. Transmission=Done
    By SLO-6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-30-2008, 01:58 AM
