Thread: 2002 gtp oil pressure?
Results 1 to 10 of 10
  1. #1 2002 gtp oil pressure?
    Zeeland, Michigan
    hey guy's i have been getting a oil light every few times when i start up my car and sometimes when i put it in reverse? is this bad? i'm not sure how to fix it. thanks guy's!
    p.s. when i put it in drive it goes away?
    -Gortox-
  2. #2 Re: 2002 gtp oil pressure?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    When the last time u checked your oil level or changed it?
  3. #3 Re: 2002 gtp oil pressure?
    Zeeland, Michigan
    oil level is fine and was changed not even 500 miles ago so i don't know if it's pressure or what?
    -Gortox-
  4. #4 Re: 2002 gtp oil pressure?
    that light only comes on when the PSI hits 5. did you change the filter when you changed the oil?
  5. #5 Re: 2002 gtp oil pressure?
    Wausau, WI
    you better pray that it is the gauge that is faulty...you will want to gett it checked out if it isn't too late already.
  6. #6 Re: 2002 gtp oil pressure?
    Zeeland, Michigan
    i sure hope he changed the filter when i bought it, i hope it's just a faulty gauge cause it flickers at random time too. thanks for the replies everyone!
    -Gortox-
  7. #7 Re: 2002 gtp oil pressure?
    Odd thing here.. Had that issue on a Regal. Ended up being a faulty cluster. But the only way to know was to hook a mechanical gauge and know for 100% certain.
    FWIW the glovebox manual said flashing was normal at idle/stoplights. My personal feeling was ...NO F'n way is that normal.
  8. #8 Re: 2002 gtp oil pressure?
  9. #9 Re: 2002 gtp oil pressure?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    There are two different lights (I'm pretty sure the GP is the same as the Regal on this), one for oil pressure and one for oil level. If it's the oil level, your sensor's probably bad. It happens. If it's the oil pressure light, hopefully it's a bad sensor as well, because if your oil pressure is dropping that low regularly, you have a problem, and it could be serious if not corrected soon.
    Come to think of it, there's probably a third light to change the oil, I'm assuming that's not what we're talking about, though.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: 2002 gtp oil pressure?
    Wausau, WI
    yes we have two different lights(one for level and one for pressure). The oil change light is in the DIC, digital or dummy bulb depending on which DIC you have..
  1. 2002 GTP vs. 2002 audi S4
    By JbrownGTP in forum Track Sessions and Kills
    Last Post: 07-07-2009, 11:50 PM
  2. 2002 gt
    By zbee in forum Introductions/Noob Questions
    Last Post: 05-04-2009, 07:04 AM
  3. 2002 gt
    By Snake in forum Introductions/Noob Questions
    Last Post: 05-01-2009, 08:38 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
