Hey everyone, hopefully someone can help me out. I follwed the directions of the bottle of prestone flush, but have some concers.
The bottle said to open the drain plug, drain the fluid, close the plug. Add the super flush, fill with water, run for 10 min with heat on high, then drain. Repeat process with water, drain. Then fill with new coolant.
My problem is i only had about no more than 4 litres of coolant come out each time. I did NOT have the engine running while the coolant was draining. Shoul I have left the plug open and drained while running the engine? The manual says it take 11 litres of cooant, but only around 4 came out, so there lots still left in there.
I didnt even get to put one full bottle of coolant in.
Thanks for all your help!
