Thread: cold air and pcm question
Results 1 to 12 of 12
josbourn1 cold air and pcm question 11-07-2012, 06:11 PM
blueguy Re: cold air and pcm question 11-07-2012, 06:13 PM
tod1d Re: cold air and pcm question 11-07-2012, 06:32 PM
smoke14 Re: cold air and pcm question 11-07-2012, 07:31 PM
blueguy Re: cold air and pcm question 11-08-2012, 10:43 AM
00grandprixgtp Re: cold air and pcm question 11-07-2012, 08:40 PM
EJOUIE Re: cold air and pcm question 11-07-2012, 08:54 PM
00GT Re: cold air and pcm question 11-07-2012, 08:54 PM
1996pontiac Re: cold air and pcm question 11-08-2012, 11:26 AM
blueguy Re: cold air and pcm question 11-08-2012, 11:31 AM
Juanmiguel Leave it there, no problem... 11-08-2012, 01:10 PM
TexasTanker19kilo20 Re: cold air and pcm question 11-08-2012, 02:24 PM
  1. #1 cold air and pcm question
    Oct 2012
    Baldwinsville, New York, United States
    so i removed stock air box and installed an intake, what do you do with pcm?
    thanks
  2. #2 Re: cold air and pcm question
    Throw it away.
    Seriously though, just leave it there or tie it down.
    It doesn't matter, it won't hurt it.
  3. #3 Re: cold air and pcm question
    May 2008
    Winnipeg, MB
    Do some more mods and then get the pcm reprogrammed.
    2007 Pontiac Grand Prix
  4. #4 Re: cold air and pcm question
    Apr 2012
    Goderich, Ontario
    I think u can buy a PCM tray from ZZP or make something to hold it down.
  5. #5 Re: cold air and pcm question
    Quote Originally Posted by smoke14 View Post
    And get bent whenever you can get one from a last generation S10/Blazer for probably a few bucks from a junkyard.
  6. #6 Re: cold air and pcm question
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    get 2 big lag bolts and run it into it in the spots you choose just make sure it goes all the way threw or it wont work correctly
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  7. #7 Re: cold air and pcm question
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Zip ties.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  8. #8 Re: cold air and pcm question
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Use a pcm tray from a Blazer.
  9. #9 Re: cold air and pcm question
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I used zip ties and it hasnt moved since. I am either going to buy a tray from Wbody store or get one from a s10/Blazer.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  10. #10 Re: cold air and pcm question
    Why.
    Leave it there, it doesn't hurt it.
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Leave it there, no problem with that.
    Sent from my GT-S5830L using Tapatalk 2
  12. #12 Re: cold air and pcm question
    Sep 2011
    Copperas Cove, TEXAS
    Mine just sits there and I have had no problem.
  1. Cold air intake question.
    By GPGT2004 in forum Engine
    Last Post: 09-23-2011, 01:20 PM
  2. cold air intake and pcm question
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 11:47 AM
  3. Cold Air Intake Question
    By Frank217 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2010, 03:01 PM
  4. Cold air intake question
    By Ramit888 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2010, 10:26 PM
  5. Cold Air Intake question
    By Kenny75k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 05:26 PM
