Thread: 2005 GT Key stuck in dash mounted ignition
Results 1 to 2 of 2
  1. #1 2005 GT Key stuck in dash mounted ignition
    SCS
    Hi all,
    My friend has asked for help and while searching for a solution I came across this great site!
    The problem: on his 2005 GT the ignition is dash mounted and the key cannot be removed. The car can be started, driven and turned off, but the key cannot be pulled out. I have found other threads refering to a similar problem, but those posts refer to a column mounted ignition switch. Any help would be greatly appreciated!
    Bill
  2. #2 Re: 2005 GT Key stuck in dash mounted ignition
    East Meadow New York
    hey
    i have the same problem. i got the key out by removing the shift lock cable out of the ignition switch. but now the car will not start due to the anti theft system. now i have no idea how to reset the anti theft system. i know this is a older post, i dont know if u fixed this problem or not.
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  3. How are your amps mounted?
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2009, 08:49 PM
  4. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
  5. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
