Thread: Spark Plug/ head problem on a 02
Results 1 to 7 of 7
cardinals1970 Spark Plug/ head problem on a... 09-28-2009, 11:00 PM
BoostJunki3 Re: Spark Plug/ head problem... 09-28-2009, 11:19 PM
rharper33 Re: Spark Plug/ head problem... 09-28-2009, 11:23 PM
cardinals1970 Re: Spark Plug/ head problem... 09-29-2009, 12:56 AM
Sabrewings Re: Spark Plug/ head problem... 09-29-2009, 01:02 AM
blueguy Re: Spark Plug/ head problem... 09-29-2009, 01:09 AM
BillBoost37 Re: Spark Plug/ head problem... 09-29-2009, 06:15 AM
  1. #1 Spark Plug/ head problem on a 02
    Lexington,KY
    I have an 2002 Grand Prix SE and my wife was driving it yesterday when it started to sound like it was going to blow the engine( Her words). So I get to where she was and pop the hood and found the center spark plug on the front side was not even in the spark plug hole. So I put it back in and the car runs perfect until I am a block from my house when it blows the same plug back out of the hole. I can't really tell if the threads in the hole are damaged but the threads on the plug look fine but now the plug will not tighten at all. It will sorta get tight but then it break free again
    So what kind of damage or cost could I be looking at to fix the problem?
  2. #2 Re: Spark Plug/ head problem on a 02
    Joliet, IL
    uhhh sounds like someone over tightened a plug and stripped the plug hole....i would assume that means you need new heads....but dont quote me on that...not sure if there is an easier way wait for bluegtp or bio to chime in on this one...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: Spark Plug/ head problem on a 02
    Nov 2008
    norman oklahoma
    i used helicoil on a old motorcycle to tighten the cylinder don't know if this is doable on a plug hole
  4. #4 Re: Spark Plug/ head problem on a 02
    Lexington,KY
    Quote Originally Posted by BoostJunki3 View Post
    Someone might have, I bought the car used the first of the year and hadn't changed the plugs yet. I really like the car and it has run great until the other day.
  5. #5 Re: Spark Plug/ head problem on a 02
    Barksdale AFB, LA
    I'd imagine a helicoil would be a viable solution. Probably still have to remove the head, but you might not have to get it replaced. Try another plug in there. If it does the same thing then the issue is with the head and it has to come out. Take it to a machine shop and see what they find.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Spark Plug/ head problem on a 02
    X2 on the machine shop...either way a 3100/3800 (LHO/L36) head shouldn't be too expensive at all.
    Or...you've got something really wrong on that piston...but I highly doubt that is the case here.
  7. #7 Re: Spark Plug/ head problem on a 02
    When you pull it apart, I'd like to see pics if possible.
    It's tough for me to imagine how a cast iron head stripped out before the threads on a plug.
  1. Spark Plug Question.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 09:45 PM
  2. Spark plug question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 05:36 PM
  3. Sooty spark plug, only one
    By IndeedSS in forum General Tech Discussion
    Last Post: 06-01-2008, 09:49 AM
  4. spark plug gapping?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 10:15 AM
  5. spark plug problem
    By dr456931 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:28 PM
