Thread: Non HD tranny into GTP?
Results 1 to 5 of 5
Lawngoose Non HD tranny into GTP? 10-01-2009, 03:44 PM
Bio248 Re: Non HD tranny into GTP? 10-01-2009, 03:50 PM
BoostJunki3 Re: Non HD tranny into GTP? 10-01-2009, 03:54 PM
Lawngoose Re: Non HD tranny into GTP? 10-01-2009, 06:01 PM
Sabrewings Re: Non HD tranny into GTP? 10-01-2009, 07:19 PM
  1. #1 Non HD tranny into GTP?
    Outer Space
    My tranny is about to take a dump, and I have been looking around for Tranny's.
    Would a NON-HD 4T65E work with my GTP? Or would I have to change axles...etc...
    I am trying to do a tranny swap on a budget, so any and all info is appreciated.
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Non HD tranny into GTP?
    you could swap it right over, but the gear ratio in the PCM will be wrong.
  3. #3 Re: Non HD tranny into GTP?
    Joliet, IL
    im gonna get a gt trans soon also and swap my hd diff from my trans onto the new one and that way ill have 3.29s on a budget ....after i fix my kr problem of course lol
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: Non HD tranny into GTP?
    Outer Space
    So the tranny lines could be different, and I would need to put the 3.29 tables via Tuner... anything else?
  5. #5 Re: Non HD tranny into GTP?
    Barksdale AFB, LA
    You'll need to keep the torque converter out of your HD trans. The L67 torque converter is a little larger and has different mounting holes. If memory serves, the L36 flex plate is dual drilled for either size.
    2009 Subaru Impreza WRX STI
  1. New tranny
    By TNTSS in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2009, 12:57 AM
  2. Im new....need some Tranny Help...think it went out!?!?!?
    By cjilek in forum Introductions/Noob Questions
    Last Post: 05-18-2009, 07:25 AM
  3. 9C1 Tranny Help
    By cobraz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2008, 11:36 PM
  4. What tranny comes with my car?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2008, 11:36 AM
  5. 9C1 Tranny Help
    By cobraz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-22-2008, 08:51 PM
