Thread: Looking for help with climate control system
Results 1 to 4 of 4
  1. #1 Looking for help with climate control system
    south carolina
    Hello guys. I found this site while searching for info on grand prix climate control issues. I need some help diagnosing my car's problem. Here is what is going on:
    *2001 Grand Prix GT(3.8 k engine) with dual climate control
    *Noticed about 2 weeks ago started running hotter than usual(from about 180 to 195 now)
    *now I am only getting warm air thru the climate system even when set for just air from outside(no ac or defrost turned on)
    *no cold air when ac on whether max or min setting
    *blower fan seems to be working properly
    *vacuum control for defrost/dash/floor working properly
    *blend door actuator working
    *engine whine when set on ac or defrost(changes as the rpms change)
    *removed blend door actuator and can move door manually easily
    *have had the radiator flushed and new thermostat installed
    Any help or ideas would be appreciated
  2. #2 Re: Looking for help with climate control system
    Donating Users Liquifire's Avatar
    Wausau, WI
    sounds to me like the coolant flow going to the heater core is stuck open, and will not bypass.
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  3. #3 Re: Looking for help with climate control system
    south carolina
    Thanks Liquifire. Is there some way to check this either under the hood or does it require the heater core coming out from under the dash?
  4. #4 Re: Looking for help with climate control system
    Wausau, WI
    unfortunately I have no experience with the heater core and do not know where the switch, relay, or anything else is. If you can find out where it would mechanically block off the coolant flow and check there to start. If I find anything else I will let you know...
  1. Climate control problem
    By LSXHP in forum General Tech Discussion
    Last Post: 07-31-2009, 01:01 AM
  2. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  3. climate control
    By gotboost3 in forum General Tech Discussion
    Last Post: 01-27-2009, 09:10 PM
  4. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
