Thread: misfires may be another issue
Results 1 to 20 of 32
  1. #1 misfires may be another issue
    Joliet, IL
    ok guys so i have been having a misfire issue at wot...cylinders 3,4,5,6 are misfiring multiple times when i floor it....now i have a intermittent misfire while idling....thought it was ignition related but everything seems alright so i also noticed while accelerating slowly i bog and nose dive like the car is gonna die, almost like im getting no fuel....maybe a clogged fuel filter or injectors hopefully its the cheap filter....ill prob replace the plugs wires and coils while im at it also...could a fuel issue cause what im describing?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: misfires may be another issue
    Nov 2008
    norman oklahoma
    yes check for clogged or inoperable injector
  3. #3 Re: misfires may be another issue
    If it isn't fuel related I'd be willing to bet your ICM might be taking a crap.
  4. #4 Re: misfires may be another issue
    Joliet, IL
    thats my next guess also because i highly doubt all 3 coils would go simultaniously...and for 4 wires to be bad would be weird also...how much is an ICM?
    00 Silvermist GTP
  5. #5 Re: misfires may be another issue
    the ICM is different from the coils...if it takes a crap it'll make perfectly good coils seem like dog sh!t...shouldn't be more than like 10 or 20 bucks from Morad.
  6. #6 Re: misfires may be another issue
    Joliet, IL
    ok yeah the fuel filter didn't fix it....im gonna get a new icm first along with new wires & plugs hopefully that cures my cars cold
    00 Silvermist GTP
  7. #7 Re: misfires may be another issue
    Jan 1970
    Maquoketa, Iowa
    Please just get some AL104's again and gap them all to exactly .05
  8. #8 Re: misfires may be another issue
    I didn't even see that...over gapping can cause crazy misfires...
  9. #9 Re: misfires may be another issue
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    did you mean .50?
    00 Silvermist GTP
  10. #10 Re: misfires may be another issue
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    he must of. i got my 104s gapped at .55 and never had a prob.
  11. #11 Re: misfires may be another issue
    Joliet, IL
    Plus if plug gap was causing my misfires wouldn't I have noticed right away after chAnging my plugs
    00 Silvermist GTP
  12. #12 Re: misfires may be another issue
    Joliet, IL
    Plug gap wouldn't cause intermittent probs I wouldn't think either
    00 Silvermist GTP
  13. #13 Re: misfires may be another issue
    Joliet, IL
    i beginning to lean toward tranny issues....it almost feels like a shift when it bogs...weird....like it bangs as if it shifted but it studders instead....or it could be all 6 cylinders not firing.
    00 Silvermist GTP
  14. #14 Re: misfires may be another issue
    Joliet, IL
    UPDATE!!!
    ok guys....i have noticed a couple things tonight while scanning....
    when i get this bog/bump/bang effect my knock shoots up above 2.0 quick and then will disapate when i let off...and when this bang bog happens i do not show up with any misfires....the bump and misfires are seperate it seems....now where do i start! AHH FML
    00 Silvermist GTP
  15. #15 Re: misfires may be another issue
    Joliet, IL
    any body?
    00 Silvermist GTP
  16. #16 Re: misfires may be another issue
    Charles City, IA
    plugs should be gapped at .055" .5" is half an inch. Not sure on your problem tho.
    SMGPFC Two Nipple General
  17. #17 Re: misfires may be another issue
    Feb 2008
    Pull out plugs 3,4,5, and 6, and check the gap on all of them. I had a problem years ago where I replaced my plugs and accidentally over-gapped the plug for #4. Everything was fine for the first few days after that, then it just 'randomly' started acting up. I had the plug at .065" instead of .055". $h!t happens...
  18. #18 Re: misfires may be another issue
    Jan 1970
    Maquoketa, Iowa
    For the last time, you are running a 3.4 setup which one of the supporting mods is a colder plug. Make sure to get AL104's, gap them PROPERLY at .05-.055 and then try again. When you go from 7psi to 12psi in boost, a colder plug is needed, you are running stock heat range plugs. If it just gets a little better but still misfires, drop down to a .045 gap and try again.
  19. #19 Re: misfires may be another issue
    Donating Users Liquifire's Avatar
    Wausau, WI
    no one can help you if you are unwilling to try some of these things...it is free to inspect and check things and what $2 per plug for new ones...
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  20. #20 Re: misfires may be another issue
    Joliet, IL
    putting in 104's tomm at .45 or .50 havent decided...and the locking up feelin i was getting was from not doing a case learn after my tune....did a case learn and boom i only have misfires now
    00 Silvermist GTP
  1. random misfires
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-14-2009, 06:26 AM
  2. Rear Bank Only Misfires
    By pontiackid in forum General Tech Discussion
    Last Post: 06-14-2009, 05:12 AM
  3. WOT misfires
    By gotboost3 in forum General Tech Discussion
    Last Post: 11-12-2008, 08:58 PM
  4. multiple misfires out of now where
    By DunriteDiesel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2008, 10:51 AM
  5. Low fuel pressure/0300 misfires
    By Arkanzan Wheeler in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 12:59 AM
