Thread: 12's
Results 1 to 20 of 29
  1. #1 12's
    Joliet, IL
    can i run 12's on street tires full weight with...
    FSIC w/ a sub 3.0 pulley
    42 lb.
    headers
    1.95 YT RR's
    L76 springs
    a dyno tune
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: 12's
  3. #3 Re: 12's
    Donating Users Uno99's Avatar
    Appleton, Wi
    WOW my best with a Cam'd 3.2 setup is 13.8 NOT A SH***Y driver either. What gives??
    A few guys at the track are tryin to call BS that Im cam'd Sorry to HI-JACK
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  4. #4 Re: 12's
    I ran a sub 13.5 with a 3.4" and a XP setup...with a 1.9 60' foot...you just gotta know how to drive. Trapped like 101-102. Then went to a 3.2" and gained like 2 mph in the 1/4 but my 60' suffered from the increase in boost. So it was pointless.
  5. #5 Re: 12's
    Donating Users blowfishRus6's Avatar
    g.a.
    track conditions and weather/altitude all play a factor.
    the track i go to is pretty close to sea level so that helps. but dont get me wrong, last time i went the DA was 3200feet about sealevel. ALOT of things factor into your time.
    those mods have the potential for 12's, but thats not to say your going to hit that. ive seen some with those same mods only go mid 13's (13.5-13.6) close to sea level. you better have a traction stratigy set up if your trying for 12's with those mods ie supension/tires
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: 12's
    an intercooler makes a BIG difference. that should be everyones first buy.
  7. #7 Re: 12's
    That and headers.
  8. #8 Re: 12's
    and screw those l76 springs. id be running 130s with those 1.95s and id run the redline to about 6400. id run it with no intercooler though. run it on e85 and run a 2.8 or so. it would tear ass.
  9. #9 Re: 12's
    Joliet, IL
    your saying run no IC and run a rocker'd e85 setup on a 2.8? that wouldnt knock?
    00 Silvermist GTP
  10. #10 Re: 12's
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Uno99 View Post
    Whose tune?
    Quote Originally Posted by BoostJunki3 View Post
    It would knock. That and you would need 65# inj. on a 2.8 with E85. I would just go with an intercooled rocker setup for now with a 3.2-3.0 pulley on 42# inj. 12's on street tires would take some nice tires and a great tune. It's about at that range that you can be assured with slicks it will hit 12's.
  11. #11 Re: 12's
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    Whose tune?
    shiiitttt if i can hit 12's non intercooled on a stock/cam heads that would be pretty cool but id rather not knock and get an IC...well an IC prob wont come till tax return time but thats ok not like i need power for winter....
    00 Silvermist GTP
  12. #12 Re: 12's
  13. #13 Re: 12's
    Banned - Busted For Scamming
    Feb 2009
    You need turbo. Much more achievable on turbo setup.
  14. #14 Re: 12's
    g.a.
    much more expensive....
    its slow.
  15. #15 Re: 12's
    about 5 grand more expensive if you are doing it right.
  16. #16 Re: 12's
    May 2008
    staten island,NY
    3.4 pulley, er rockers, plog, 2.5inch dp, hai, n* tb
  17. #17 Re: 12's
    Joliet, IL
    Quote Originally Posted by QwikGT View Post
    er rockers? is that like modified 1.9's sorry im slow haha
    00 Silvermist GTP
  18. #18 Re: 12's
    Appleton, Wi
    The launch is key......Has anyone tried Nitto DR's do they actually help. They did wonders on my LS1 T/A
  19. #19 Re: 12's
    May 2008
    staten island,NY
    nittos arent the best for the gp....i have hoosier qtps
  20. #20 Re: 12's
    May 2008
    staten island,NY
    zzps l36 rockers. i had the l36 with the m90 kit at that time. so to answer another question you can run split ratio rockers on a supercharged car
  1. Now I really need To get my car into the 12's
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-06-2009, 12:01 PM
  2. Ideas for a high 12's low 13's build?
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 05:53 PM
