Thread: Safe to run 3.2?
Results 1 to 14 of 14
  1. #1 Safe to run 3.2?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Well i finally got my self a tuner, and all i can say is that i don't know how it survived without one.. anyways i was doing some logging and i am running on 0 kr somehow i did multiple scans and they all came back the same so do you think it would be safe for me to drop pulley sizes? also my car is maxing out at 6 pounds of boost... has ever since i put on a different blower
    Mods:
    * Alt. Rewire
    * ZZP Shiftkit
    * ZZP 3" cat-less downpipe
    * 3.4 pulley
    * SLP Power-Flo Cat-Back exhaust
    * ZZP Plog and Crossover
    * 160 T-stat
    * TDC Racing Intake
    * ZZP Ported Lower Intake
    * Stage2 Ported Blower
    * TDC Racing 10.4 MM Wires
    * 1.84 Rocker arms w/ pushrods
    * Custom tune
  2. #2 Re: Safe to run 3.2?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    I think u would atleast need 2 go with headers instead of the plog 4 a smaller pulley and like 2-3 step colder plugs.
  3. #3 Re: Safe to run 3.2?
    Feb 2008
    What's your timing look like at WOT? If you're not up close to or at 20*, then you should just add timing to what you have. If you can get 20* of timing at WOT, then dropping a few pulley sizes would be safe.
    FYI, I was running my P-Log on my XP/3.1 setup with no problems. You will probably benefit by switching to headers, though.
  4. #4 Re: Safe to run 3.2?
    St. Louis
    Quote Originally Posted by DanGTP View Post
    i'll have to check tom. the laptop died shortly after bringing it inside but lucky everything saved, but thank you for the advice i wil be sure to check it out
  5. #5 Re: Safe to run 3.2?
    GEORGIA
    Just stating what ive read on smaller pulleys
  6. #6 Re: Safe to run 3.2?
    Feb 2008
    NP. If you have any questions you can't find quick answers to online, feel free to PM me, and I'll try and help. I'm still relatively green with my tuning, but I've made a lot of mistakes and learned a whole lot!
  7. #7 Re: Safe to run 3.2?
    SE Level Member bensett004's Avatar
    michigan
    just curious where can i get a tuner?
  8. #8 Re: Safe to run 3.2?
    St. Louis
    Quote Originally Posted by bensett004 View Post
    ZZ Performance
    or you can find someone that is selling a DHP Power Tuner on the forums.. i know there are a few people at 3800pro.com that are selling theirs
  9. #9 Re: Safe to run 3.2?
    the only way youll run a 3.2 is on low timing and thats no fun to drive. keep your 3.4 for now.
  10. #10 Re: Safe to run 3.2?
    St. Louis
    thanks for the info bio
  11. #11 Re: Safe to run 3.2?
    but then again, you might have a freak so the only way to know is to try it out and scan.
  12. #12 Re: Safe to run 3.2?
    Just slap the bish on...I mean...what is the worst thing that can happen? A learning experience or the blown motor? LOL
  13. #13 Re: Safe to run 3.2?
    Oct 2008
    Northern Illinois
    How do you like the ZZP shift kit? Everyone's saying go intense but its like $20 vs. $120.
  14. #14 Re: Safe to run 3.2?
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    i had your setup but i had headers, and 42.5's. i was able to tune to 0 knock on the stock cam and valvetrain. however my timing was around 15-16* so it was low enough to be safe... just my $.02
  1. Determining Safe Pulley Size with L67 & M90 [*]
    By gmboy in forum How To Write-Ups/Tech Tips
    Last Post: 06-18-2010, 11:56 PM
  2. 1.8rr safe for a stock motor
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 03:32 PM
  3. Safe RPM Limits??
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-14-2008, 07:55 PM
  4. Is it safe to coast in Neutral?
    By DesQ27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2008, 10:39 AM
  5. This looks like fun & safe
    Last Post: 06-29-2008, 09:13 PM
