Thread: Engine wiring harness ground location?
Results 1 to 2 of 2
  1. #1 Engine wiring harness ground location?
    Feb 2009
    NE
    On my 97 GT I was getting a DTC code for the TPS. I replaced the TPS and still got the DTC right after clearing it. After posting about that another forum reader told me a few things to check and it if was not that confirm the black wire to the TPS was a good ground. Sure enough I found 3 ohms to ground on that wire. So, i put a temp. ground on the black wire to the TPS and the DTC code stopped. So, I assume the engine harness ground is not good. Anyone know where the engine harness gets its ground?
  2. #2 Re: Engine wiring harness ground location?
    GT Level Member tylerbinski's Avatar
    Canada
    There are a couple grounds.. I believe the fans, PCM and the Battery are all ground at the bell housing.. (starter bolt under the car by the flexplate)
    I just took him off, cleaned and put back. there are 3 wires going here, jack up the car and take a look.)
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  1. engine wiring harness
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2009, 08:32 PM
  2. zzp wiring harness
    By TheOtherNick in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 02:47 PM
