can having air in the coolant lines cause any major problems? other than temp issues? ive bled it after changing stats but not 100% that i got all of it whats the worst that could happen?
If you're running Dex, yes, it can cause problems. Air destroys the anti-corrosion barrier the coolant builds up, leading to rust.
It can over heat. If it has not, or you are not running hot, then you should be fine.
Doesn't the T-stat elbow have a bleeder screw like my GT?
I haven't seen these cars to work on yet, but you should be able to bleed air out of the system. if the radiator has a cap, take it off while cold, start the car, turn heat on, let air run out of the system, fill radiator as necessary, close the radiator cap. Basically you want water to overflow from the radiator. But maybe these cars only have a radiator cap on the reservoir...
Air in the system causes overheating problems.
yes.....it has a bleeder on the waterneck. Also, leave the cap off of the radiator while getting it up to temp. Then top it off and put the cap back on. You should be fine.
