Thread: 2000 Grand Prix Electrical issues
Results 1 to 5 of 5
  1. #1 2000 Grand Prix Electrical issues
    SE Level Member Stappen720's Avatar
    RockVegas MA
    wondering if anyone has any ideas of what the hell is up with the car........the running lights wont work anymore, the gauge cluster light doesnt work....the DIC doesnt work......the fog lights only work when you flick the high beams on........and when you click mode on the DIC it beeps as if you left your door open or left your lights on when u leave your car.........something is wrong........fuses are fine
    2000 Grand Prix GTP -- TEP TRANS , TURBOCHARGED. PT67 /1.9 Mod Rockers/CC Valve Springs 105's/Plog/48lb Injectors / Borla Exhaust/ Cartuning PCM / KYB Struts/K&N Intake/Autolite 103/ SD Appearance Package / Tuned by Deekster Derek and Myself ------------------PB - 13.7 at 102.4 MPH <<< soon to be broken!!!
  2. #2 Re: 2000 Grand Prix Electrical issues
    Guam
    Did you check all the grounds on the car using a service manual?
    Possibly the BCM is going south.
  3. #3 Re: 2000 Grand Prix Electrical issues
    morris
    Quote Originally Posted by Stappen720 View Post
    I had to replace the multi-functional switch in my 2002 gt for around $235.00.That switch can create a series of electrical mafunctions.
    My brights were running one on and one off until I changed it.
    It is the switch that controls,cruise,wipers,turn signals
  4. #4 Re: 2000 Grand Prix Electrical issues
    GT Level Member tylerbinski's Avatar
    Canada
    Check harness for corrosion infront of the battery in the bundle... if so - repair wires.. had a similar issue.. my airbag light would also flash, and system voltage fluctuate occasionally
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  5. #5 Re: 2000 Grand Prix Electrical issues
    RockVegas MA
    checked all of the above except the turn signal, cruise control switch........iv been deciding whether to replace that or not
  1. 2000 Grand Prix Tachometer/Trac Light/Stall Issues
    By ZackN in forum General Tech Discussion
    Last Post: 09-26-2013, 11:40 AM
  2. 98 Grand Prix Electrical problem
    By soulmonger in forum General Tech Discussion
    Last Post: 07-01-2009, 04:10 PM
  3. 1991 Grand prix issues- HELP ME
    By Fastline42 in forum General Tech Discussion
    Last Post: 06-25-2009, 02:20 PM
  4. 2002 Grand Prix Gt issues, need some expert advice
    By gtpx02 in forum General Tech Discussion
    Last Post: 06-10-2009, 11:19 PM
  5. 97 grand prix power options issues
    By redspace in forum General Tech Discussion
    Last Post: 03-18-2009, 05:34 PM
