Thread: Help 2001 Grand Prix water pump removal
Results 1 to 7 of 7
  1. #1 Help 2001 Grand Prix water pump removal
    Friend Nebraska
    How do I remove the last water pump bolt behind the crank pulley?Do I have to pull the crank pulley and if so how?
    Thanks
    Rick
  2. #2 Re: Help 2001 Grand Prix water pump removal
    i do not recall u ned to remove the crank pulley to remove only the waterpump. there are only 8 bolts all together tor remove the pump, i think 3 are 13mm and the rest are 10mm IIRC.
  3. #3 Re: Help 2001 Grand Prix water pump removal
    Friend Nebraska
  4. #4 Re: Help 2001 Grand Prix water pump removal
    HUDSON
    that looks like the power steering pulley.
    Dean
  5. #5 Re: Help 2001 Grand Prix water pump removal
    Charles City, IA
    unbolt the power steering pump and move it out of the way.
    SMGPFC Two Nipple General
  6. #6 Re: Help 2001 Grand Prix water pump removal
    Donating Users blowfishRus6's Avatar
    g.a.
    turn the powerstearing pulley till the holes line up with the bolts on the powerstearing pump. unbolt them and set it aside now you can get to the last water pump bolt.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: Help 2001 Grand Prix water pump removal
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    learned a couple things here.... have to remove the p/s pump to get to the water pump, and..... after 25 years of living here, i just leanred this state has a town called Friend, weird. first thing i thought was "you've got a friend in friend"
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  1. Radiator and Water Pump replacement 95 Prix SE Coupe
    By Soultempter in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-20-2009, 12:08 AM
  2. 2001 grand prix TCC help
    By lynnjones in forum Introductions/Noob Questions
    Last Post: 07-25-2009, 06:24 PM
  3. 2001 stock grand prix gt
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-18-2009, 11:32 AM
  4. Rim Spec for 2001 Grand Prix SE
    By ricez in forum Tires & Wheels
    Last Post: 07-30-2008, 08:30 AM
  5. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
