Ok i have a wierd problem here as far as my heater blower. I bought the car about a month and a half ago and the heat settings would only work in the #5 position. I was told that the resistor is the problem (have not changed yet). I have since gotten the key fob for my viper system that was on it and when i use the auto start the heat works in every position 1-5, but as soon as i put the key in and push the brake (turning off the auto start and having the car in normal running) the heat goes off, the DRL's go off and the information center goes out. As soon as i turn it to 5 or off everything comes right back to normal. ????????
Now with my HUD it was originally not showing on my windshield. I was driving the car home from where i bought it (2.5 hour drive) and it got dark so i stopped and i decided to look through the windshield into the HUD and i could see the speed showing a 0. I was thinking that maybe it could be the dimmer switch for the HUD so i was tapping on it and got no response. Since then i have not even been able to look through the windshield and see anything at all. There is no display at all. Could this just simply be the dimmer switch?
BTW the car is a 97 GP GTP 4Dr.
