Thread: random misfires
Results 1 to 11 of 11
BoostJunki3 random misfires 09-13-2009, 12:48 AM
FoSHO99 Re: random misfires 09-13-2009, 01:44 AM
BoostJunki3 Re: random misfires 09-13-2009, 01:48 AM
FoSHO99 Re: random misfires 09-13-2009, 01:55 AM
BoostJunki3 Re: random misfires 09-13-2009, 02:08 AM
TheOtherNick Re: random misfires 09-13-2009, 12:00 PM
BoostJunki3 Re: random misfires 09-13-2009, 02:24 PM
TheOtherNick Re: random misfires 09-13-2009, 02:29 PM
BoostJunki3 Re: random misfires 09-13-2009, 02:57 PM
TheOtherNick Re: random misfires 09-13-2009, 10:06 PM
BoostJunki3 Re: random misfires 09-14-2009, 06:26 AM
  1. #1 random misfires
    Joliet, IL
    hey guys every once in awhile i punch it in my car and ill studder terribly and i can feel it misfiring bad...wondering what it could be ignition module or coils maybe?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: random misfires
    Jan 1970
    Maquoketa, Iowa
    Should switch to AL104's.
  3. #3 Re: random misfires
    Joliet, IL
    i had al104s in before and it still happend...tried 605s this time to see if i could get away with it for better idle/mileage
    00 Silvermist GTP
  4. #4 Re: random misfires
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by BoostJunki3 View Post
    Ideally you would want to run 104's, but you could probably change wires/packs or clean them until the issue is solved.
  5. #5 Re: random misfires
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    ok thanks good to know...
    00 Silvermist GTP
  6. #6 Re: random misfires
    Charles City, IA
    If you could scan you could switch the coils around to see if the miss follows a coil.
    SMGPFC Two Nipple General
  7. #7 Re: random misfires
    Joliet, IL
    good idea....how come my aeroforce is reading 0 misfires tho?
    00 Silvermist GTP
  8. #8 Re: random misfires
    Charles City, IA
    Are you in the missfire setting that shows all 6 cylinders?
  9. #9 Re: random misfires
    Joliet, IL
    yes do i need to have that up while doing a pull or does it monitor record them so when i open it it shows past misfires that have occured over time?
    00 Silvermist GTP
  10. #10 Re: random misfires
    Charles City, IA
    It is only in real time. So you have to have it open when doing the run.
  11. #11 Re: random misfires
    Joliet, IL
    ok thanks
    00 Silvermist GTP
  1. Rear Bank Only Misfires
    By pontiackid in forum General Tech Discussion
    Last Post: 06-14-2009, 05:12 AM
  2. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
  3. multiple misfires out of now where
    By DunriteDiesel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2008, 10:51 AM
  4. Low fuel pressure/0300 misfires
    By Arkanzan Wheeler in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 12:59 AM
