Hey All, i know i asked this prior in one of my tune up threads, but does anyone have Photos of where the PCV is on my 97 GT? im going to be doing some fall matinence and this is on my list, thanks!
REMOVAL PROCEDURE:
Remove the injector sight shield from the fuel rail and intake.
Remove the MAP sensor (1).
Use a 16 mm socket to press the access cover (2) down and rotate 1/4 turn counterclockwise.
Remove the access cover.
Remove the PCV valve (3) and the O-ring (4) from the intake manifold.
INSTALLATION PROCEDURE:
Install the crankcase ventilation valve (3); replace the O-ring (4) if necessary.
Install the access cover (2).
Install the MAP sensor (1).
Install the sight shield.
Do not forget to re-use the #4 O-ring! If not, you will get a strange, continuous honking sound when you start the engine.A vacuum leak!
I did this, I mean no I didn't!![]()
