Thread: 98 gtp idling bad..
Results 1 to 7 of 7
  1. #1 98 gtp idling bad..
    SE Level Member jessiinicole's Avatar
    Florida
    Hello all, to quickly summarize my issue.. I had blown the head gasket, heads went to machine shop put it all back together with new spark plugs start it up did not idling right had a little miss drove good just idled bad. Check engine comes on giving code PO303 so changed the ignition wires. Ran really good next day check engine on yet AGAIN now 2 codes PO341 and PO300. It is driving me crazy someone please help!
  2. #2 Re: 98 gtp idling bad..
    P0341 is a camshaft position sensor. Most likely it was bumped in the replacement of the head. Check the wiring to the sensor and ensure it's connected.
    P0300 Random multiple misfire. Do you know what plugs were put in the car?
  3. #3 Re: 98 gtp idling bad..
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    could timing be off? thatd cause the crank code and misfires
  4. #4 Re: 98 gtp idling bad..
    Florida
    The wires were from Auto Zone.. Duralast i believe? Why are they no good? What would you recommend?
  5. #5 Re: 98 gtp idling bad..
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    they meant, check the wires going to the sensor, not the spark plug wires.
  6. #6 Re: 98 gtp idling bad..
    SE Level Member Supercharged's Avatar
    Round Lake, IL
    The question was what spark plugs were used? Brand and Part number, need to ensure they are correct heat range plugs.
  7. #7 Re: 98 gtp idling bad..
    Nov 2008
    Revere, MA
    Supercharged, that makes good sense to check the plugs and their gap
  1. 2000 GP SE problems starting and idling
    By the daveman in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-05-2009, 08:40 AM
  2. Temperature creaps while idling?
    By MARKS99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2009, 12:25 PM
  3. engine idling high
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 11:49 PM
  4. 1994 GP SE Knock Knocks like a joke when idling
    By robertrod in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-02-2009, 10:46 AM
  5. gtp having trouble idling
    By ibanez0110 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:37 PM
