Thread: Dual climate control issue
Results 1 to 2 of 2
mr_gtp Dual climate control issue 12-22-2009, 04:56 AM
toolguy Re: Dual climate control issue 12-22-2009, 07:14 AM
  1. #1 Dual climate control issue
    monroe,wi
    ok so i have a 2001 gtp with dual climate control, the analog setup, and i am wondering why the passenger side always blows cold air when its on. The driver side blows warm air but the passenger side is freezing!! I knoticed i have a coolant leak some where near the radiator but i keep it full of antifreeze until i can get a new radiator. Any way what do you think the heat issue is??
  2. #2 Re: Dual climate control issue
    Guam
    This is covered on the site too...
    In short, the passenger side temperature actuator needs to be replaced. It is an electrical part that moves the door according to what temp you want. Both drivers and passengers side actuators work together, when in driver or single mode. You would think only in passenger mode would that side blow cold, but that is not the case. Yours is broken or stopped in cold, or next to cold.
    The part new is not cheap, I got a used one for $50. To get to the part, remove the glove box and the cloth panel attached to it. Remove the glove box and the panel will come with it.
    See this link for more, Temp door act right hand side.
    http://www.grandprixforums.net/f73/b...ent-21941.html
  1. how do ya reset dual climate control
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 06:25 AM
  2. 98 GTP dual climate control-metric?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-26-2009, 03:41 PM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  5. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
