Thread: unbelievable amount of sludge in oil pan
Results 1 to 9 of 9
  1. #1 unbelievable amount of sludge in oil pan
    SE Level Member john cola's Avatar
    Sep 2012
    willmar minnesota
    On Friday I discovered coolant in my oil. the milkshake syndrome. I bought a lower intake gasket kit and will change them monday, but today i drained the oil...and there was an unbelievable amount of the thick sludge in there. completely filled my oil drain pan to the top...i slid a coffee can in there, it filled to the top, slid another oil drain pan under and about 1/3rd filled that. It's hard to believe my poor 3800 can survive this. has this happened to anyone else? how did it turn out?
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Poor maintenance has consequences. Not saying you did it. You could drop the pan and clean it. Run some BG oil flushes through with oil changes every 1000 miles for a few thousand miles. If there is sludge in the pan, its probably everywhere else too.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I Hear 4q oil and 1q trans fluid will clean it up well. Use Castrol gtx oil.
    Sent from my Galaxy Nexus using Tapatalk 2
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  4. #4 Re: unbelievable amount of sludge in oil pan
    Well if your LIM gasket blew out, the mass amounts of coolant mixed with the oil is going to make the milkshake/sludge.
    If thats the case then almost everything is going to have coolant on it/in it be it the crank and main bearings, cam bearings etc etc.
    I would change the gaskets and buy lots of cheap oil to pour down the valley and to dump in the crankcase. Maybe rotate the motor by hand for a while to help get it around and clean it out before you start the car up.
  5. #5 Re: unbelievable amount of sludge in oil pan
    St. Louis
    I wonder if you could get away with disabling fuel and spark and spin the motor w/ the starter. Would it still move enough oil to flush out any coolant left in the bearings? I hope we're not seeing the beginnings of another rod knockin 3800
  6. #6 Re: unbelievable amount of sludge in oil pan
    GT Level Member Toms04compg's Avatar
    Michigan
    Yeah he could do that. Pull your fuel pump fuse throw some peak or whatever is cheap your way and crank it a hole bunch of times, like what you do when you rebuild your motor.
  7. #7 Re: unbelievable amount of sludge in oil pan
    Do the LIM gaskets. Likely one blew out into the lifter valley.
    To spin the motor w/o fuel and spark, simply leave the ICM connector unhooked. If that were mine, I'd do the gaskets, drop in a fresh cheap oil change. crank it a bit and look at the dipstick. If not foamy or crazy, start the car and let it run a minute. DRain and do another oil change. Repeat until your oil is clean and decent again.
  8. #8 Re: unbelievable amount of sludge in oil pan
    Bettendorf, IA
    I recently bought a 60k mile 3800 Series II from 1996 Regal. Took the oil pan off to clean it and there was 1/4" of sludge on the bottom. What a mess. The crank and cylinder walls were stained dark color. So, even though it was old persons car, they probably changed oil once a year because mileage took forever to reach. I wonder if it will do well. I'm going to look into the BG.
    When the guy pulled it for me he left engine outside. Took me little over a two weeks to get it picked up with my truck.Noticed it no longer had the oil fill cap on it. wonder how much dust dirt got in the engine. THoughts how to protect the engine before running it? or?
  9. #9 Re: unbelievable amount of sludge in oil pan
    Very little likely got into it. Just ensure you drain the oil out and treat it like any other motor.
  1. Drain and refill amount
    By TEK310 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 01:18 AM
  2. Estimated amount to sell new ZZP stage II IC kit?
    By geforcextreme in forum General Tech Discussion
    Last Post: 10-23-2011, 12:05 PM
  3. Have a small amount of cash. DP, HV3, or PLOG?
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 09:45 PM
  4. Gross, unbelievable and funny all in one.
    By Abrasive in forum Off Topic Discussion
    Last Post: 01-25-2009, 04:07 PM
