Thread: There's trans fluid everywhere!!
Results 1 to 2 of 2
  1. #1 There's trans fluid everywhere!!
    Nov 2008
    Chicago
    This is actualy on my 96 Dodge B2500 w/ a 5.2 magnum. I changed the trans cooling lines (i saw fluid where the rubber was crimped onto the rest of it), and the pan gasket and washed the underside off. I started it back up and as soon as I put it back into gear, fluid starts leaking from the bell housing drain. Could this be caused by too much fluid or is it more likely an internal leak?
    Thanks!
  2. #2 Re: There's trans fluid everywhere!!
    Charles City, IA
    Sounds like a front seal or a pump seal/ gasket.
    SMGPFC Two Nipple General
  1. How much fluid do i need? Thanks
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2009, 07:50 PM
  2. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  3. I guess a newb question about trans fluid
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2008, 02:00 AM
  4. trans fluid level
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2008, 02:45 PM
  5. Recommended Trans Fluid
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-20-2008, 05:57 PM
