Thread: Noise in Front Driver-Side Tire Well
Results 1 to 4 of 4
  1. #1 Noise in Front Driver-Side Tire Well
    Chicago
    Chats
    Hi All,
    I recently purchased a 2004 GTP Comp G, and every time after I put my car into drive there is a rude sound that emanates from my front driver side wheel well. I am not terribly well-versed in cars, although I speculate that perhaps it is my ABS cycling.
    After the initial noise my car drives fine.
    Has anybody else experienced this phenomena, and if so should I be concerned? How do I fix it?
    Thanks
  2. #2 Re: Noise in Front Driver-Side Tire Well
    Wausau, WI
    Chats
    this is quite vague..........any chance of getting a video of the noise?
  3. #3 Re: Noise in Front Driver-Side Tire Well
    Charles City, IA
    Chats
    3061
    Its the abs pump running when you first move more than likely.
    SMGPFC Two Nipple General
  4. #4 Re: Noise in Front Driver-Side Tire Well
    Chicago
    Chats
    Thanks 01GTP.
    So is this occurrence something that I should have checked-out by a mechanic, or is it common?
  1. front end squeaking/metallic noise on drivers side
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 07:36 PM
  2. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  3. '04 Driver Side Air Vents
    By Sabreslight in forum General Tech Discussion
    Last Post: 07-11-2009, 12:41 AM
  4. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  5. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
