Thread: gto swap
Results 1 to 20 of 23
  1. #1 gto swap
    Feb 2009
    NEW BEDFORD
    how much more hp does a gto have over a 97 gtp & is it possible to put a computer,engine & tranny from a gto into a 97 gtp just trying to find a smarter and easier way to go faster
  2. #2 Re: gto swap
    GTO has a lot more power stock, its an ls1/ls2 versus an l67. however, to dump that motor in a grand prix is going to take A LOT of custom fabbing that i have no idea if you can do or not.
  3. #3 Re: gto swap
    Wausau, WI
    it is about 70-100 more crank HP than the gtp depending on which motor. It will take a lot of work to get this in there if it is possible.......it would be easier and cheaper to just buy something like a 98 Z28 to start with....
  4. #4 Re: gto swap
    Barksdale AFB, LA
    It is nearly impossible. It can be done, but there's so much modifying to everything that has to happen first that it's out of reach for most people who don't work in or own their own machine shop.
    2009 Subaru Impreza WRX STI
  5. #5 Re: gto swap
    Jan 1970
    Maquoketa, Iowa
    basically take a sawzall to the underside of the grand prix, cut everything out until you can literally walk, still touching the ground, from the engine bay back to the trunk of your car. Then fab up a new frame and you are now ready to start fabbing up everything else. It's similar to a top swap.
  6. #6 Re: gto swap
    Feb 2009
    NEW BEDFORD
    why a 98 z28
  7. #7 Re: gto swap
    Quote Originally Posted by CHAMPS97 View Post
    why a 98 z28
    Because it is already RWD and has a LSx motor in it.
    If you want a V8 RWD car you should have bought a FBody...not a WBody
  8. #8 Re: gto swap
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    lol
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  9. #9 Re: gto swap
    Wausau, WI
    why a 98 z28
    they are probably the cheapest price wise of the LS1 cars. LS motors are awesome for power and reliable and this is the most affordable option on average for getting an LS based vehicle
  10. #10 Re: gto swap
    Dec 2008
    Canada
    Quote Originally Posted by Liquifire View Post
    Or buy a 240sx and swap an LS1 into it
  11. #11 Re: gto swap
    GT Level Member BoostedComp's Avatar
    Youngstown
    haha yeah just a bolt or two different
  12. #12 Re: gto swap
    Apr 2009
    stockton ca
    I say do it prove every one wrong
  13. #13 Re: gto swap
    Jersey
    then it won't be a gp anymore. There will be nothing gp about it.
    16' wrx sti- stock
  14. #14 Re: gto swap
    look more into a ls4 swap from the GXP's yeah its more cost friendly to do a supercharged v6 but......I see it like this buy a wrecked GXP ive seen drivers for for 5500 to 6500 that lot drive and no air bags blown. swap the engine trans, tap shift, all the seats, the gxps way better brakes, the wheels, and then sell the rest of the parts! I wanna do this to my 2 door 02 red GP so bad. An ls4 with a small shot of nos! Whats up then!??? It can be done cost effectivly if u buy the whole wreck.
  15. #15 Re: gto swap
    Feb 2009
    NEW BEDFORD
    i"m sorry fellas i didn't know the gto was rear wheel sorry for the confusion does anyone know how to terminate a thread thanks
  16. #16 Re: gto swap
    SE Level Member singularity's Avatar
    Houston, Tx
    If you want a V8, pick up a northstar V8, and mid-mount the engine.
    or put ANOTHER L67 in the rear, and run dual engine. Seen it done on a few different cars.. 500 AWHP
  17. #17 Re: gto swap
    GTO...didn't...know...RWD...LOL
    Quote Originally Posted by singularity View Post
    Mid mount the engine? cmaaaaaaaaaaaaaaaaaaaan. Not happening.
  18. #18 Re: gto swap
    SE Level Member cardiffGIANT98gtp's Avatar
    Kansas
    I tell what would be cool is if you stick with the gtp drivetrain and figure out some way to make it AWD. I think some of the vibes were AWD, you could probably figure out some way to use the differential out of it... but idk, prolly more work then i'd put into a GP. BUY A G8!
  19. #19 Re: gto swap
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by cardiffGIANT98gtp View Post
    The Vibe had a Toyota engine and transmission, slight difference there.
    The Volvos and I think the Aztec used an AWD version of the 4T65E. There's been talk of retrofitting a GP, but I don't know that anyone's actually done it.
    2001 Buick Regal LS - Almost Stock
  20. #20 Re: gto swap
    Barksdale AFB, LA
    Quote Originally Posted by Scimmia View Post
    The transfer portion of it is weak, and it's still biased as FWD until it starts slipping. Only then does power get transferred to the rear wheels.
  1. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-02-2009, 05:32 AM
  2. L67 Top Swap on 05 L26
    By Luda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2009, 10:53 AM
  3. What wil i need to do a top swap
    By gp3800t in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 08:34 PM
  4. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
