Thread: 04 gtp, tic tic tic tic when trying to start
Results 1 to 4 of 4
  1. #1 04 gtp, tic tic tic tic when trying to start
    SE Level Member busagtp's Avatar
    chicago
    I just completed a tune-up, wires and plugs, car started and i drove around a couple blocks, car riding good no problem. Now when i try to start it up i get a very fast tic tic tic tic tic. My battery is good, What else could it be? Could i have bothered something when pulling the plugs in the back of the engine, it is a very tight spot?
  2. #2 Re: 04 gtp, tic tic tic tic when trying to start
    Topeka, KS
    Bad ground your not getting full power to the starter.
  3. #3 Re: 04 gtp, tic tic tic tic when trying to start
    Wausau, WI
    It could be the starter...or it could be that the starter is not getting the power.......how did you check the battery? Did you check the alternator to make sure that the battery is charged on start up? Go over all of your wires to see if they are corroded or loose for the alt/ starter/ and battery.
  4. #4 Re: 04 gtp, tic tic tic tic when trying to start
    Topeka, KS
    True but most likely he's got loose wiring, bad ground, or corroded wires that need cleaning.
    Start with the simple stuff first... Then dig deeper!
  1. Car won't start
    By 03GTPFour in forum General Tech Discussion
    Last Post: 08-04-2009, 03:03 AM
  2. where to start
    By Jakegday in forum PCM Tuning
    Last Post: 08-04-2009, 12:51 AM
  3. Where should I start on my 07 gt?
    By 07gpgt in forum General Tech Discussion
    Last Post: 04-30-2009, 03:15 AM
  4. Help car won't start
    By gtora69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 05:48 PM
  5. Let me start over
    By vermsta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2008, 06:02 PM
