Thread: Stripped Turn Signal Cover Screw
Results 1 to 4 of 4
  1. #1 Stripped Turn Signal Cover Screw
    Indiana
    This might be an easy fix but I guess I'm not that mechanically inclined and Firestone wants to charge $100 to fix it.
    The issue on my '04 Grand Prix GT...
    My Driver side front turn signal is out, which is usually a very easy fix but the screw holding the cover on (the circle one near the bottom) is stripped. [side rant, I've never opened that cover in 75k miles and I got the car when it had 8k]
    Since that screw is rather small, I haven't been able to find an extractor that looks small enough. And since the screw is recessed, I can't get a dremmel in there to notch a new slot. Any thoughts on how else I could proceed?
  2. #2 Re: Stripped Turn Signal Cover Screw
    Aug 2008
    KCMO
    drill it out
  3. #3 Re: Stripped Turn Signal Cover Screw
    Wausau, WI
    what he ^^^ said
  4. #4 Re: Stripped Turn Signal Cover Screw
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Go up to sears, they have some screw extractors. I think they are like 50 dollars for a set. like 6-7 of them but atleast you will have the tool next time you goof.
    My EX wifes other car is a broom.
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Turn Signal Module
    By Clar2478 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:02 PM
  3. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
  4. Turn signal Issues
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 10:39 AM
  5. Turn Signal on Solid
    By coolken84 in forum General Tech Discussion
    Last Post: 08-31-2008, 01:39 AM
