Thread: abs and traction control light on...why???
Results 1 to 17 of 17
  1. #1 abs and traction control light on...why???
    altus ok
    Hey guys, i have an 03 se model and just this week i noticed my abs and traction control lights on, anyone know how i can correct this?
  2. #2 Re: abs and traction control light on...why???
    in a house
    Usually those 2 lights mean you have a bad wheel bearing or sensor.
  3. #3 Re: abs and traction control light on...why???
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    in my case, it was a bad connection between the computer and the front passenger side ABS sensor. be sure to inspect all wiring.....
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: abs and traction control light on...why???
    London Ont, Canada
    ive got the same problem, when i got the car they said it was a sensor under my seat? or soemthing... but they said teh ABS works.. well thankfully i didnt have to wait until winter to find out, NOPE doesnt work... i went sliding the other day in a rain storm..
    so now i wanna know how to fix it and how much it will set me back.. HELP!!
  5. #5 Re: abs and traction control light on...why???
    Wausau, WI
    get it scanned to hopefully find out which wheel it is...........and hope that it is just one wheel bearing.......
  6. #6 Re: abs and traction control light on...why???
    CT
    You can scan it and find out? Would you be able to do this with a regular hand scanner or does it require an expensive one from a shop?
  7. #7 Re: abs and traction control light on...why???
    Nov 2008
    Fremont Nebraska
    cant do it with a regular obd2 code reader. you can get a pretty decent abs code reader from $100-$150 on ebay if you search for "actron"
  8. #8 Re: abs and traction control light on...why???
    London Ont, Canada
    will that scanner only work for that? if im shelling out $100+ i wanna be able to use the thing for all my scanning/tuning needs LOL
  9. #9 Re: abs and traction control light on...why???
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    Does your a/c work? if the a/c clutch fuse is blown it will put on those 2 lights on my 98 gtp it is fuse 13 under the hood try it...
  10. #10 Re: abs and traction control light on...why???
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    10 amp fuse in fuse box underhood could be blown or missing. forgot the number location but i take mine out when i want to boil the tires off. its labled abs module i beleive.
  11. #11 Re: abs and traction control light on...why???
    SE Level Member davidl25's Avatar
    Apr 2009
    evansville in.
    It does most of the time mean a bad wheel bearing.
    99 GP (SE) GT Clone, KYB AGX struts + SSC springs, GMPP sway bars, GMPP trailing arms, OTTO strut tower brace,Big 3 mod, Stage 2 voltage booster, alt rewire, 180 t stat, HID conversion, D/S rotos and ceramic pads,cold air intake, and an insane car audio setup 150+ db.
  12. #12 Re: abs and traction control light on...why???
    London Ont, Canada
    how much is one of thoes?
    is it normally only one? or can all 4 be bad?
    im new to car repair.
  13. #13 Re: abs and traction control light on...why???
    Wausau, WI
    if it is an abs sensor usually it is just one............but it could also be the ABS controller........which is next to your brake master cylinder and this does control more than one tire.......that is why you need to get the code read to find out...
  14. #14 Re: abs and traction control light on...why???
    altus ok
    thanks for the input guys, i have also noticed the blower fan for the ac is only working on 5, 1-4 theres nothing, would this tie into any of this?
  15. #15 Re: abs and traction control light on...why???
    Charles City, IA
    Quote Originally Posted by jtheripper211 View Post
    That is probably the blower motor resistor.
    SMGPFC Two Nipple General
  16. #16 Re: abs and traction control light on...why???
    altus ok
    where is the blower motor resistor located?
  17. #17 Re: abs and traction control light on...why???
    Wausau, WI
    It's electrical harness plugs into the blower motor and is held in by a couple of bolts/screws on the passenger side of the vehicle. I think you can access it from under the dash if I remember correctly.
  1. traction control problem
    By Martin 04 in forum General Tech Discussion
    Last Post: 07-02-2014, 11:12 AM
  2. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
  3. Surprise! ABS/Traction Control
    By BANDIT in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2009, 02:57 PM
  4. ABS/Traction control
    By holsports in forum General Tech Discussion
    Last Post: 03-22-2009, 11:32 AM
  5. Adding traction control
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-05-2009, 09:25 PM
