Thread: Important: ZZP Retainer Issues
Results 1 to 18 of 18
  1. #1 Important: ZZP Retainer Issues
    Hi guys, A Riviera guy recently had issues with stock rockers rubbing on the outter edge of some retainers.
    The parts he has on the car are cam, 105# springs, retainers etc and he's been hearing noise. Further inspection found the rockers rubbing on the retainers.
    Left is a new Intenese retainer, right is the now used ZZP retainer.
    He mentions having to file the retainers to get the valve locks out to swap them. In contacting ZZP, they stated to him that there is nothing wrong and that these are the same retainers they have been selling. Odd issue though, another Riviera guy purchased the ZZP retainers, started to notice an issue and didn't use them.
    Here's the full thread.
    ticking noise, scuffed valve spring retainers
    Just wanted to toss an FYI out in case anyone picks up ZZP retainers and things don't appear to fit properly.
    Joe: They aren't answering his calls and only replied to his emails that there is not a problem with the retainer.
  2. #2 Re: Important: ZZP Retainer Issues
    Donating Users blowfishRus6's Avatar
    g.a.
    thanks for the heads up. you can clearly see where they went wrong.
    are these the modified retainers??? makes me wanna go check mine out now.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Important: ZZP Retainer Issues
    They are the modded retainers, yes.
    One suggestion/idea on another forum was that the HD valve locks might have let the retainer sit higher than the valve tip. Guess this was a problem in the past with CC Ti retainers and CC HD valve locks.
  4. #4 Re: Important: ZZP Retainer Issues
    Bastard Reptile's Avatar
    Kansas City, MO
    Rubbing the way it did on the retainer though, wouldn't that be a rocker issue?
    I'm not a fan of modded retainers, but I'm kinda curious how this happened.
  5. #5 Re: Important: ZZP Retainer Issues
    If the locks allow the retainer to sit higher, then the rocker can touch. That's what appears to have possibly happened.
    But...if the guy buys the locks and retainers from a place..you think they'd have put that combo together many times before.
  6. #6 Re: Important: ZZP Retainer Issues
    Found that if you want to remove springs that have ZZP retainers/HD locks you need to hit the retainer to free the locks from the retainer before you attempt to compress the spring and remove it.
    Found some pics I had taken a while back.
    And a car that I'm currently working on.. I said to him "ZZP retainers and HD locks right?" and he confrimed.
  7. #7 Re: Important: ZZP Retainer Issues
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    It looks like those retainers will allow the spring to be slightly decompressed when the valve is closed. I wonder what kind of problems that will cause.
  8. #8 Re: Important: ZZP Retainer Issues
    Not at all. The LS springs we use when we upgrade expect an install height of 1.800" and with most retainers and locks, we can only pull out 1.78X" install height.
  9. #9 Re: Important: ZZP Retainer Issues
    Apr 2009
    Fort Worth TX
    Oh that's right! Those retainers are designed for the LS spring upgrade. I'm interested in this thread because I might be going this route. If there is a rocker clearance issue why can't I relieve the bottom of the rockers with a good ol' grinder? Just throwing this out there...beat me up if you must.
  10. #10 Re: Important: ZZP Retainer Issues
    Or you could use Intense retainers and locks.
  11. #11 Re: Important: ZZP Retainer Issues
    Apr 2009
    Fort Worth TX
    Thanks for the info.
    In the last pic are those ZZP or Intense? I thought the ZZP's were black anodized.
  12. #12 Re: Important: ZZP Retainer Issues
    The last pic on teh engine, those are ZZP retainers. Verified by the owner of the car, Bill Stewart.
  13. #13 Re: Important: ZZP Retainer Issues
    Apr 2009
    Fort Worth TX
    Has ZZP changed something?
  14. #14 Re: Important: ZZP Retainer Issues
    I dunno, you had a serious picture fail.
  15. #15 Re: Important: ZZP Retainer Issues
    Apr 2009
    Fort Worth TX
    yep
  16. #16 Re: Important: ZZP Retainer Issues
    Apr 2009
    Fort Worth TX
    There we go..ZZP retainers.
  17. #17 Re: Important: ZZP Retainer Issues
    Might be flash in the pic that makes them look silver. IIRC they are black.
  18. #18 Re: Important: ZZP Retainer Issues
    Apr 2009
    Fort Worth TX
    Yea, I guess but the taper on the top looks different. I'll bet this is an old pick on ZZP's web site.
  1. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
  2. 05' gp gt issues!!!! - please help!!
    By Billyb in forum General Tech Discussion
    Last Post: 05-17-2009, 09:20 PM
  3. BOV issues
    By rodman in forum Turbo
    Last Post: 03-27-2009, 09:00 PM
  4. inner tie rod issues
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 06:47 AM
