Thread: Window Problems
Results 1 to 10 of 10
  1. #1 Window Problems
    GXP Level Member
    Theworld
    My 98 GTP Passenger window wont stay up, the cable is broken.
    How do I go about repairing this?
  2. #2 Re: Window Problems
    GXP Level Member
    Theworld
    No one knows?
  3. #3 Re: Window Problems
    Donating Users Liquifire's Avatar
    Wausau, WI
    get a new one? do you mean you need the procedure to replace the cable?
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  4. #4 Re: Window Problems
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You get a new regulator and replace it.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Window Problems
    Wausau, WI
    if yours is a two door, I am not sure if you can just get a regulator.......I believe they are only sold as a motor/ regulator combo. Atleast that is all that was available at the time I replaced mine...
  6. #6 Re: Window Problems
    GXP Level Member
    Theworld
    Mines a 4 door, and the cable is snapped, not sure how to go about fixing it.
  7. #7 Re: Window Problems
    Wausau, WI
    I am not sure.......if it is cracked in the right spot and it is not in the way, you may be able to get something to use to crimp it together. Otherwise not sure how else you could repair it without replacing it....
  8. #8 Re: Window Problems
    Dublin, OH
    This posts gives some step by step instr.
    http://www.grandprixforums.net/f81/r...write-299.html
    Not sure if you fixed this, but currently working on my RR window motor/regulator.
    Here are the steps I have taken:
    1. Checked power to the switch - good.
    2. removed motor and tested off regulator - good
    3. manually turned regulator - tough but works
    4. put motor back on - works, but draggs some and sticks.
    That is where I am. Bought a reman motor only from NAPA for $42, but now wondering if I need a new regulator as well. Ran out time tonight, so will take the regulator off in morning and inspect. I might only need to clean tracks and lubricate, but still might replace motor, unless it works flawlessly. Might have my 6 yr old test it.
    Hope this helps.
  9. #9 Re: Window Problems
    Wausau, WI
    he was talking about specifically fixing the cable, not why he is having problems with the window.
  10. #10 Re: Window Problems
    Odessa, MO
    You can't just fix the cable. You will need a new regulator assembly. Options include: dealer, ebay, or some parts stores are now carrying them as well. Remove the door panel and unbolt the old one and bolt the new one in. Not really too difficult to do.
  1. Window fog. How to get rid of?
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-10-2013, 12:49 PM
  2. window problems
    By dvaughn in forum General Tech Discussion
    Last Post: 07-31-2009, 05:06 PM
  3. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  4. 1999 Grand Prix GTP rear passenger window & locking problems
    By RYANPOWERSMAIL in forum General Tech Discussion
    Last Post: 05-24-2009, 03:51 AM
  5. Window Problems
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2008, 05:02 PM
