Thread: Radiator plug
Results 1 to 8 of 8
  1. #1 Radiator plug
    virginia
    2002 Grand Prix. I could only turn the plug 1/4 turn and no coolant drained. Should the plug turn further or is the drain plugged? I don't want to break the plug!
  2. #2 Re: Radiator plug
    GXP Level Member
    Theworld
    I wound up braking my plug.
    I just took the hose on the passenger side off and drained it that way.
  3. #3 Re: Radiator plug
    Donating Users Liquifire's Avatar
    Wausau, WI
    mine only turned a quarter of the way.....it did not drain well until the small blockage was removed........use a coat hanger or something to get in there. I dont believe it opens more than that without breaking it. Mine drained pretty fast after blockage was cleared and it was only open a quarter turn........fwiw
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  4. #4 Re: Radiator plug
    Guam
    The drain on my 99 is a POS! Horrible and hard to get to. Easy to see but hard to turn!
  5. #5 Re: Radiator plug
    Wausau, WI
    Hard to get to? It may be hard to turn, if it has not been used in a long time, if ever. It is extremely easy to get to though. Reach straight in from the top.
  6. #6 Re: Radiator plug
    Guam
    Mine just really was not. What you describe is like what is on my Vibe, this was not however. It had nothing to grab into, just a slot on the top of it. I ended up using pliers to turn the damn thing out!
  7. #7 Re: Radiator plug
    Wausau, WI
    Quote Originally Posted by toolguy View Post
    Mine just really was not. What you describe is like what is on my Vibe, this was not however. It had nothing to grab into, just a slot on the top of it. I ended up using pliers to turn the damng thing out!
    yours must have been broken or replaced with something other than stock. the stockers have a tab that you just grab onto and turn. I see why you would think that it is harder without something to hold onto though.
  8. #8 Re: Radiator plug
    SE Level Member Supercharged's Avatar
    Round Lake, IL
    Mine wouldn't budge and I wasn't about to break it, so I did the lower radiator hose instead.
  1. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  2. Special tool needed for radiator drain plug on 2000 GP?
    By halfwit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2009, 09:31 PM
  3. Radiator fan on 96 GP won't work
    By Boatman in forum General Tech Discussion
    Last Post: 05-17-2008, 07:43 AM
